aHorseofCourse 261 #1 Posted October 15, 2017 Axle seals are leaking real bad on the tranny in my 308. Found one local from a C-145. Question, is it an 8 pinion with 1 1/8 axles and will it fit my 308? Also, what's it worth? Thanks for any help. Share this post Link to post Share on other sites
Ed Kennell 38,703 #2 Posted October 15, 2017 Why not put in new seals? 2 Share this post Link to post Share on other sites
slammer302 2,155 #3 Posted October 15, 2017 SKF9815 seal would be for the 1" most auto parts stores will have them. The trans from a C-145 will fit. But changing seals are not hard to do. 1 Share this post Link to post Share on other sites
aHorseofCourse 261 #4 Posted October 15, 2017 I'd like the heavy duty trans for my engine upgrade. The plan is to rebuild the new one and just swap them out. Then rebuild the original and keep it for future projects. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,102 #5 Posted October 15, 2017 C-145 should have this transmission. Click on the picture Garry 1 Share this post Link to post Share on other sites
aHorseofCourse 261 #6 Posted October 16, 2017 Thank you Garry, that helps. Share this post Link to post Share on other sites
