Similar Content
By Joe Warren
A guy I know runs all his 4 cycle power equipment engines on 2 cycle fuel. He claimed it reduced engine wear. Aside from the added cost of the 2 cycle oil, are there other downsides. Just curious what you all think.
Joe
And now for the rest of the story: I spoke to the guy again. He was a mechanic at a place where they operate a lot of outdoor power equipment; with both 2 and 4 cycle engines. To prevent employees from putting straight gas into their 2 cycle machines, all their fuel got 2 cycle oil mix with it. For them, it was more economical to spend money on oil, than on blown engines and downtime.
Thank for all the great posts. I found some to be very entertaining.
By JoeM
The Ethanol Monster strikes again!
Got out the pressure washer and went to start it, "no dice"
Opened the carb and found those typical ethanol pearls, as I call them.
I used an additive in my fuel last year, Ethanol Shield, did not seem to work very well.
Not wanting to drive 30 miles for fuel, and still skeptical about if it is true ethanol free.
Switched over to Lucas additive now.
Will see.
FYI
Joe
By RJ Hamner
Let me first say that it ran when I brought it home. Drove it around the guys yard, tried out the mower, drove it onto the trailer and drove it off the trailer and into the garage.
I've done a "ground up" restore on the tractor (70 Charger 12). Swapped out the breakerless for a battery ignition and swapped out the 10 amp for a 15 amp stator, flywheel and regulator.
Pulled the head, looked pretty good, new head gasket and head bolts.new fuel pump, fuel lines,new switches and wiring, new aftermarket carb, new coil, coil wire, new points, new throttle and choke cables.
Static timed (twice just to make sure) Have tried Autolite 216's and the hotter 437's. changed the condenser to the high dollar Kohler one.
It will idle but when I give it some throttle it stumbles or will rev up a little then quits.
I've gone thru the "trouble shooting " steps multiple time and to no avail
Anyone got any ideas?? I am willing to try most anything at this point
Bob
By Team70R
Waiting on the eBay electric fuel pump to show up for the C165. Only thing I'm not sure about is what to do with the old mechanical one. Do I just leave it in place or do I need to make a cover plate with the a gasket and remove it?
By Bigwatersig
So I rebuilt carb and replaced fuel pump, thought fuel pump would fix my problems. No such luck! Still stalled out when she got hot. Took apart fuel tank shutoff, cleaned and lubed o ring, knocked some dirt out of vent tube with long wire, blew long fuel line, drained tank and tried some air pressure both ways, tank fuel outlet, and thru vent tube. Doesnt allow hardly any air flow either way? What is between tank and vent tube? A really small orifice, or some sort of pressure valve vent device? Put it back together and ran her with coffee filter banded over cap, NO PROBLEMS! Was so glad to move some dirt that I never tried putting cap back on! I think maybe there was blockage at tank shutoff, valve was very stiff and difficult to turn. Looks like a major ordeal to access fuel tank???
I will try putting fuel cap on tomorrow, but I had ran her prieviously with cap loose so I think my problem is solved. Vent sure doesnt seem right though?
