wholdguy 73 #1 Posted October 9, 2017 Hello all, my current problem with mowing the lawn and all the leaves, the 42 inch side discharge gives up furrows of leaves on the lawn. What works best for attaching to the discharge opening on the deck to force the leaves to mulch into smaller pieces? This is a 1970's era deck and does not have a disharge chute like the newer models. Thanks, G. Share this post Link to post Share on other sites
Jerry77 1,218 #2 Posted October 9, 2017 There are a lot of attachments for that problem...I have always just windrowed them and then keep running thru them until they disappear...I think that is good for the ground too...I use side discharge also.....lots easier than handling them more than once too... 3 1 Share this post Link to post Share on other sites
ericj 1,578 #3 Posted October 9, 2017 I bought a 89 520-HC this summer that came with a 42" RD recycler mower deck. I did like said above and windrowed the leaves into row and then got the tractor out that I currently have the recyler on. I was surprised at the great job it did making all the leaves disappear. I'm glad to add this deck to my arsenal of equipment to combat my yard duties. I will also use it when I trim my hedge row to grind up the branches and leaves from that job. I usually use either a 48" SD deck or a 60' deck to mow the yard every week. eric j 2 1 Share this post Link to post Share on other sites
Ed Kennell 40,498 #4 Posted October 10, 2017 38 minutes ago, ericj said: I'm glad to add this deck to my arsenal of equipment Just curious Eric, How many tractors are required to qualify as an arsenal? You don't have to count em, just a ball park figure....20, 30, 40, 50...... 1 1 5 Share this post Link to post Share on other sites
ericj 1,578 #5 Posted October 10, 2017 I refuse to answer that on the grounds that I might incriminate myself eric j 3 minutes ago, Ed Kennell said: Just curious Eric, How many tractors are required to qualify as an arsenal? You don't have to count em, just a ball park figure....20, 30, 40, 50...... 3 3 Share this post Link to post Share on other sites
953 nut 57,932 #6 Posted October 10, 2017 50 minutes ago, Ed Kennell said: Just curious Eric, How many tractors are required to qualify as an arsenal? You don't have to count em, just a ball park figure....20, 30, 40, 50...... That would be an Armada, not an arsenal! 4 Share this post Link to post Share on other sites
wholdguy 73 #7 Posted October 10, 2017 I only own one Wheelhorse and one mower deck. So, I guess my older mower deck is not the mulching type of deck like the newer ones seem to be. The leaves basically go shooting out from the mower and aren't chopped up. I am trying to come up with something to block off the discharge opening to help get the leave chopped. I am looking at some old screening sitting in the garage. This has openings of 3/8" x 3/8". If I use this to block off the mower, maybe it will start to mulch. What do you think? G. Share this post Link to post Share on other sites
953 nut 57,932 #8 Posted October 10, 2017 2 minutes ago, wholdguy said: looking at some old screening sitting in the garage. This has openings of 3/8" x 3/8". If I use this to block off the mower, maybe it will start to mulch. What do you think That should work, or perhaps some expanded steel. 1 1 Share this post Link to post Share on other sites
ericj 1,578 #9 Posted October 10, 2017 41 minutes ago, wholdguy said: I only own one Wheelhorse and one mower deck. So, I guess my older mower deck is not the mulching type of deck like the newer ones seem to be. The leaves basically go shooting out from the mower and aren't chopped up. I am trying to come up with something to block off the discharge opening to help get the leave chopped. I am looking at some old screening sitting in the garage. This has openings of 3/8" x 3/8". If I use this to block off the mower, maybe it will start to mulch. What do you think? G. that's one of the beauty of wheel horse tractors, the decks come out from under the tractors so easy , if you can find a recyler deck you can swap it out for leaf duty and use the SD deck for regular mowing's good luck on what ever you decide to do eric j Share this post Link to post Share on other sites
wholdguy 73 #10 Posted October 10, 2017 Yes Richard, Later this week I will take the screen and attach it to the mower deck and give it a try. Wish me luck. Thanks G. 1 Share this post Link to post Share on other sites
Tankman 3,520 #11 Posted October 10, 2017 (edited) On 10/9/2017 at 9:50 PM, wholdguy said: Yes Richard, Later this week I will take the screen and attach it to the mower deck and give it a try. Wish me luck. Thanks G. Hope it works well. Be sure to post results, we need to know! Somewhere, don't remember, thought I saw side discharge plugs. Toro mulching kit pictured below. Edited October 11, 2017 by Tankman 1 Share this post Link to post Share on other sites
wholdguy 73 #12 Posted October 12, 2017 So today, I tried this to help mulching leaves with this mower deck..... Took an old metal license plate and zip tied the four mounting holes to the deck outlet. I found out that the best mulching action happens when I drive around in reverse. This chops the leaves the best, believe it or not. G. 2 Share this post Link to post Share on other sites
Ed Kennell 40,498 #13 Posted October 12, 2017 I found something similar when mowing a newly seeded area that had been covered in straw. The rear bagger push mower would only pick up the straw when going backwards. Share this post Link to post Share on other sites
sorekiwi 761 #14 Posted October 13, 2017 I used to cover the discharge shoot with a plug made from a few layers of chicken wire (Mesh). It worked well, These days I pick them up with a sweeper and dump them on the vege garden. Share this post Link to post Share on other sites
ebinmaine 70,751 #15 Posted October 13, 2017 13 hours ago, wholdguy said: I found out that the best mulching action happens when I drive around in reverse. ..... 13 hours ago, Ed Kennell said: The rear bagger push mower would only pick up the straw when going backwards. These things clearly prove that we really DO live in a backwards world. 1 Share this post Link to post Share on other sites
Sarge 3,464 #16 Posted October 13, 2017 I have found over the years that using reverse does work better with the WH decks - otherwise they just seem to either pile them up in front of it or blow them out of the way instead of cutting them up . My 48" I normally run with dual blades blows them ahead of the tractor the worst due to the additional air flow . Doesn't seem to matter if it's running hi-lift blades or Gators , same problem . There is some success to just lifting the deck to transport height and running into the piles - that seems to work pretty well , then drop it to the mowing height and hit 'em again . I still get better results just picking them up and using the Stihl to mulch/bag/dump them into the trailer . Best thing I suppose is just to use a lawn vac attached to the deck , but a decent one can get really expensive quick . Have found some nice deals on several on CL but they will all need a new hose adapter or one made to fit our decks....something to keep in mind if purchasing used . Sarge 1 Share this post Link to post Share on other sites
