"Manic-Mechanic" 1,228 #1 Posted October 9, 2017 (edited) I can only guesstimate this engine is 11hp. Anyone know if the bearing would endure a PTO? What is the value new in the box? Edited October 9, 2017 by Oldman Share this post Link to post Share on other sites
Achto 28,801 #2 Posted October 9, 2017 You're correct in your estimate of 11hp. The crank on that engine is supported by roller bearings, so I believe that it should handle the PTO with no issues. 1 2 Share this post Link to post Share on other sites
"Manic-Mechanic" 1,228 #3 Posted October 9, 2017 estimate what one should pay? Share this post Link to post Share on other sites
Achto 28,801 #4 Posted October 9, 2017 that engine is a bit older, but here is a current price on a 12hp model. https://www.jackssmallengines.com/jacks-parts-lookup/part/robin/ex350de5012 Spoiler 1 Share this post Link to post Share on other sites
R. L. Addison 299 #5 Posted October 9, 2017 Check to see how heavy the bearing/seal caps are. I have an AENLD Wisconsin that I would not trust in the long run as it has stamped sheet-metal rertainers. 1 Share this post Link to post Share on other sites
"Manic-Mechanic" 1,228 #6 Posted October 9, 2017 Little update, charging system of the W1-390. All self contained minus battery. I thought to run some wires up to a key switch no biggy....... W1-390d.docx WR-W1-340_W1-390(1).pdf On 10/8/2017 at 10:23 PM, R. L. Addison said: Check to see how heavy the bearing/seal caps are. I have an AENLD Wisconsin that I would not trust in the long run as it has stamped sheet-metal rertainers. I'll get a picture as the pulley is off right now. Share this post Link to post Share on other sites
Achto 28,801 #7 Posted October 10, 2017 That should make a good replacement engine. The company I work for used the Robin engine in some of their generators for a while, they were the quietest 3600rpm gens that we made. We stopped using them only after getting out of the portable gen market. 1 Share this post Link to post Share on other sites
"Manic-Mechanic" 1,228 #8 Posted October 10, 2017 It is a nice engine, said to be the best one they ever made? We shall see....... 1 Share this post Link to post Share on other sites
