elliot ness
D200 W/ loader BIG project
elliot ness
Started another Big Project this morning. D200 With a Ark 550 Loader, got the loader off, needs all new lines, strip the paint and Paint, then start on the tractor, the starter is not engaging, I think its the starter drive, It sat out side for over 7 years, the loader has a good bucker and a wt. box. Will add more pics as I progress. I also have a center grader blade for this beast. This could be a all winter project. I have to get the loader frame work off yet. If someone wants the Tractor, I would take 300.00 cash just the way it sits, no loader. just the tractor.
Dan693
Always have said.....a D-200 is my mini Chevelle LS6 find. Truth is I cant imagine the massive amount of work to rehab this....much less a Chevelle.
Good luck Bro!
"Manic-Mechanic"
Excellent find! If I could be so lucky! You'll enjoy this rebuild, very satisfying indeed!;)
Pollack Pete
Nice D-200.I've re-habbed worse than this one.I like the vinyl wrap on the steering wheel.I had one on my first car when I was 17 yrs old.White 1965 Chevy  Corvair.Haven't seen one since.Have fun with your project.
pfrederi
Great find Loader looks good.  One suggestion, the hydraulic reservoir for the loader is the left hand support column.  if it sat out for several years there could be corrosion inside from condensation and rust chunks .  There is a suction line screen in the bottom hose connection to reservoir.  Clean it and I would add a spin on hydro filter between the valve bank and the top of the reservoir.
Cvans
:text-goodpost:
Texas Todd
Make er shine Larry!
wh500special
Was that the one in Brighton?
If so, I saw the ad and thought twice about giving him a call.  Nice find.
Steve
Alliemorgan
How much is a 953 going for with blade plow and disk ( And Runs) ?
elliot ness
Steve
Yup.
elliot ness
More pics of the project.:)
Edited by elliot ness
more pics
  • Excellent 2
FatJackDurham
What kind of prep work did you do before painting? I am curious because it seems like you went and painted everything in place, rather than removing every piece and painting separately. Isn't it hard to clean dirt and grease out of all the nooks and crannies? I would think the paint would not last as long. Tell us about it?
Sarge
I'd have to say that took some serious pressure washing and maybe abrasive blasting .
What's up with the governor ?
Sarge
elliot ness
Sarge
Gasket was leaking, ordered a new one. should be in in 2 wks.
It was blasted with HOT water twice and I finished underside with lots of elbow grease. hand sanded the sides. It's only going to be a work tractor. If I was looking for one to make show room this one would not have been a picked. It sat out side not running for 10+ years, and the right hand side was near a road where it got sprayed with  salt in the winter. As for how long the paint will last, best guess if it put in after using 20 yrs maybe?
Searcher60
That looks absolutely fantastic!
slammer302
Looks great! I also like the winch setup on ur trailer.
elliot ness
Thanks, I have used that setup [winch] for years on all my small trailers. It has winched many almost dead horses up on the bed and home.
:twocents-02cents:
slammer302
I've been using a small hand crank winch on my small trailer its very handy. I never thought about adding a idle pulley like you have.:handgestures-thumbupright:
spindley
Did you get your 300.00 for the tractor?       Is it still available?       Im droolin.
elliot ness
Sorry, the 300.00 was before I started the rebuild, when I am done it might be for sale again.
  • Similar Content
    • BuffaloD200
      By BuffaloD200
      Hey all, I need to install a drive belt on my 75 D180 for my snowblower.  I've looked through a bunch of D-series owner's manuals, and none seem to mention replacement procedure.  The PTO pulley is fixed, save for engaging the PTO and there is minimal movement at the snowthrower pulley. There's no idler or tensioner as far as I can tell.  Do I have to remove the PTO pulley?  That seems to be a required service item.
      Same question for my 80 D200 as well really.
      Using the recommended 4L490W belt.
      Thanks
    • BuffaloD200
      By BuffaloD200
      Hey all, I'm doing my first fluid change on my new-to-me D200.  Refilling the transmission is proving to be quite the struggle.  I've attempted to fill the tranny through the dipstick with a variety of funnels, but the oil just spills over the top.  I may have managed to get a quart in.
      What am I missing?
    • cbj75
      By cbj75
      I have a 1975 D200 Wheel Horse with front mount dozer blade, package includes Wheel Horse Dump Trailer, 48" belly mower side discharge, Wheel Horse front and rear wheel weights, turning brakes, rear PTO and 3-point to 2" receiver attachment, and Brinley twin disc harrow. Rear luggage/rack carrier, All refurbished, sandblasted and painted Ford red in 2016. Lots of extra Wheel Horse parts included.
      Package price $3000.00.
      Bryce Johnson
      102 Anglers PT
      Mc Cormick SC 29835
      913-638-6788
      IMG_1962.HEIC IMG_1965.HEIC IMG_0279.HEIC
    • Crazy Old Red Horse
      By Crazy Old Red Horse
      Barn find 1975 D180. 608 original hours. Tractor and 48” belly mower look to be still in their original paint. Rear 60” finish mower looks like it has had one coat of new paint added at some point. Open to trades. Please email me with any questions or for additional photos. 35 miles north of Pittsbugh.
    • wh315-8
      By wh315-8
      Grandpa wouldn't line up in right way.  Stubborn. Nice day today, got some of my herd out. 315-8 w/42" deck to mow. D200 to disc w/tandem disc. 520H w/36" tiller. And RJ59 with 36" Parker Sweeper. These horses done me well today.
