a.dumont
Starter Solenoid Location?
a.dumont
Just picked up a 1973 Auto 18. Battery, starter solenoid, and all wiring have been modified and replaced. Trying to go back to the original. I have a wiring schematic, but no images to show the location of where the solenoid mounts, etc. If anyone has a comparable model with a Kohler twin cylinder engine, please take some photos of your wiring harness, solenoid location, etc. and post below.
Edited by a.dumont
pacer
Sitting in the seat the solenoid is/was located mounted to the frame on the right side under the battery tray, if its not there you should see the 2 holes left from the original mount. From factory its HID behind a panel and its a nightmare to get to with out removing it. (as the years have gone by, I decided a while back to just leave that panel off!);)
Sarge
The gap on the right side behind the engine flywheel - on the frame as said . Yes , it's a real pain to locate it without those panels removed and it fits tightly against the panel itself . I've never found any good pics of how the wiring was routed through there , but I just re-did mine yesterday during re-assembly and I can get a pic of how I did it to protect the battery cables .
Sarge
a.dumont
Sarge,
I'd appreciate a few pictures of your rewiring. I may need to do more work to this than originally expected just to get it functional. Once everything works, I be doing a full overhaul.
Anglo Traction
This image is from Hodge71's (Jeff in PA) post in the Gallery section here. I believe the Solenoid location can be seen here?. Not familiar with the Model but clearly an advantage of having an up-to-date gallery of models/images. Hope this helps.
post-1339-0-12838500-1390929035_thumb.jp
  • Thanks 1
Sarge
Sorry - totally forgot to grab some pics when I was inspecting the pump hunting an oil leak - will get some shortly....
Sarge
Sarge
Here you go -
Last pic is from the left side - facing the right frame rail just behind the engine . It's no real fun getting to that solenoid - easier to hook the battery cables to it first , them mount the unit to the frame . Make sure it's well grounded to the frame - otherwise the coil in it can't work to make the contact between the two main terminals .
As with so many of these tractors - this is not original . I have no idea nor can I find any good pics of how the wiring was originally routed . I just took the best path I could find to keep it away from the pump's directional linkage and all the brackets so any vibration wouldn't eat through a cable . I used Keps nuts to help with frame grounding and there is a ground wire running from one mounting bolt of the solenoid over to the mounting bolts on the rectifier and then up to the battery negative post . This prevents having to rely on metal to metal contact to complete the ground circuit on these things and any issues in the future . I too would love to see exactly how the original setup was routed - it's a tight spot due to how the pump is mounted in the tractor .
Sarge
  • Similar Content
    • indywheelhorsenut
      By indywheelhorsenut
      Started fine 2 weeks ago.  I left key in ignition and fear grandson may have turned it slightly to right a week ago.. not enough to engage starter but perhaps enough to drain battery.
      Went to start it yesterday and no charge at all.  Started charging it and battery began to take charge.  However starter turned over but didnt turn engine over.
      Question is do I just need more of a charge (more amps) or do I have another problem?
      Lol, have 5 inches of snow headed here starting tonight so I need to get ahead of this today.
