JeremyF 13 #1 Posted October 5, 2017 Good morning all, I was wondering if anyone has a drawing or measurements for a blade angle handle that is bent to go around the brake pedal. I have a 412-8 and have a blade for it, but it has the straight handle on it so it blocks the brake pedal. I have the means to bend a new handle if I had a drawing or measurements. Thanks for the help! Share this post Link to post Share on other sites
Walt 339 #2 Posted October 6, 2017 Mine was bent when I got it and hit the brake pedal so I reversed the bend to clear it. Then some time later last fall T-MO needed help with making one for his. I posted drawings I made with measurements to his post asking for help. He then did 3D drawings of it. So I would suggest you contact him or look for that thread to see if that would work in your case. Share this post Link to post Share on other sites
Tankman 3,518 #3 Posted October 6, 2017 I cut one and welded a horizontal piece of flat bar in. Works great. 1 Share this post Link to post Share on other sites
