Raider 2 #1 Posted February 13, 2009 I have a couple of leaks on my C-160. The worst is the short hose running from the lift valve to ram, I believe it is the pressure side. It leaks fast at the elbow fitting at the ram when the plow is up. The fitting is tight at the ram but the pivoting fitting itself is sloppy. There is also a minor leak on one of the big hoses from pump to lift valve, it might be just loose. I have looked for these hoses on the Toro lookup and Jack's Small Engine. A couple are discontinued and the remaining are quite expensive. I can't tell which is which on the Toro website drawings (they aren't shown in the drawing but the part numbers are there). Does anyone know which part number is the pressure hose to the lift ram? Is this a common item besides just Wheelhorse. I wouldn't mind a substitute if it all works the same. Are there alternatives or components I could use to make up a new hose? I have a Tractor Supply Store and Farm and Fleet store handy and also a Toro dealer. My C is no beauty queen, I just want it to work right so I'd like to fix this leak soon. Thanks much Share this post Link to post Share on other sites
Raider 2 #2 Posted February 13, 2009 Here's the drawing I'm looking at: Share this post Link to post Share on other sites
kj4kicks 154 #3 Posted February 13, 2009 Hi Raider, I sell complete sets on my website: http://www.classickitchensandmore.com/whee...new-p-1223.html You may be able to get your's made locally, but they need to be made at a hydraulic shop. Due to the pressures, they are crimped lines. Hope that helps. E. Share this post Link to post Share on other sites
Raider 2 #4 Posted February 13, 2009 That's great, do you take paypal? Will I need to purge the lines after swapping in new ones? Share this post Link to post Share on other sites
kj4kicks 154 #5 Posted February 13, 2009 Yes on the Paypal. The site will take you through registration and shipping/payment options. The lines will clear themselves in a few seconds just by operating the lift valve in both directions. Don't forget to make sure the drive belt is engaged, of course. Thanks, E. Share this post Link to post Share on other sites
kpinnc 13,758 #6 Posted February 14, 2009 The worst is the short hose running from the lift valve to ram, I believe it is the pressure side. Just FYI on this, and forgive me if I misunderstood your post- but BOTH lines to the cylinder on a Wheel Horse are pressure sides. The cylinders are dual-acting. Kevin Share this post Link to post Share on other sites
Raider 2 #7 Posted February 14, 2009 Eldon, I'll likely be buying a set of hoses from you once I get it approved with the accountant Would the 'kj' in your screen name have anything to do with Jeeps? If the cylinder is dual action I could get down pressure with the right linkages then? I wouldn't want that for plowing snow of course but if I were to try dozing dirt or something.. My leak would be on the hose that provides lift then I think. Thankyou guys for the help. I'm glad I can get the parts and knowledge here to get the horse fixed up. Share this post Link to post Share on other sites
kj4kicks 154 #8 Posted February 14, 2009 KJ is for karaoke jockey. Did that for 11 years. Gator is 100% right about the dual action cylinder. Yes, with a solid link you can produce down pressure. Share this post Link to post Share on other sites
