Countdown To Christmas!
Bill D
1992 416 H Transmission Input Shaft Seal
Bill D
Hi,
Does anyone have a part number and source for the input shaft seal on my 1992 416 H.  This is the shaft at the top of the transmission that the motion control linkage connects to.  The Toro part number I found on Partstree is 56-3130.  If this is the right part number, it lists for $24.00.  Is there anything out there that is better and cheaper?  Thanks.
Bill
Edited by Bill D
953 nut
If you know the inside diameter, outside diameter and thickness of the seal you could get one from any good industrial supply house.
Bill D
I don't have the measurements, and I didn't want to disable the tractor until I had a seal in hand.
