Countdown To Christmas!
R310WH
High/low shifter location
R310WH
I am new to this forum but have owned a 310-8 for 30years.  I just replaced the needle bearings and seals on the axle and reinstalled the transmission . It was a long project because I was waiting for parts. Now that I have attached the trans to the tractor I  have a question; I can't remember if the high/low gear lever goes under/over the shaft that operates the brake. I have attached pictures in hopes someone can let me know if that lever goes under or over that part.
Thanks
pfrederi
Under ..Pic is my 310-8  Great little machine!!!
Welcome!!!
Edited by pfrederi
  • Excellent 2
953 nut
:WRS:             Glad you found us and hope you will continue with us.
KC9KAS
@R310WH :text-welcomeconfetti: to :rs:
R310WH
Thanks for the your help and the picture helps a lot .
