RedRanger
HL-5 light bar template
RedRanger
Does anyone have the HL-5 light bar template that they can post up?  The one floating around last year has been erased by photobucket.
Thanks in advance.
Edited by RedRanger
Racinbob
This is what I had saved. According to the thread the bar would wrap around this. Thanks to @dclarke :)
Edited by Racinbob
  • Like 5
RedRanger
Thanks Bob.  Wanted to share it with a buddy, but Photobucket has blocked the old links.  I also found a copy in my computer.
ebinmaine
Thanks in advance.
What's that template used for?
Racinbob
It's a template to shape the support bar for the HL-5 headlights. :)
RedRanger
  • Excellent 2
Sarge
I always felt it was a bit odd how the lights sit , you'd think the bracket would have had an opposing angle to match to set them 90* to the ground...?
Still , it is quite a look , especially on the older round hoods...
Sarge
Racinbob
I know what you mean Sarge. I had the HL-5s on my 854 and did a minor modification so I could turn the lens so the 'grooves' were horizontal. Nice job making that Redranger. :)
formariz
That always bothered me a bit. Actually those "grooves" are designed to be vertical. Then one gets the correct light spread and range. That is why the "bug eye" lights actually provide better lighting since lenses are about clear.
  • Similar Content
    • chompinthebit
      By chompinthebit
      Hi all,
      i bought this 1961 701 in fall of 2018 and restored it. I completed it in fall of 2019 and I wanted to show some pictures of before during and after I got it done. I did my research and tried to make this tractor as close to original as possible. The few exceptions are tires, wiring and the steering support. Not a perfect tractor but sure is nice enough for me.
      all stainless hardware
      Rustolium stops rust Primer
      Rustolium Regal Red enamel paint
      powder coated wheels and seat
      Glenn Pettit Reproduction dash
    • Lane Ranger
      By Lane Ranger
      If anyone has a HL-5 Headlight setup on their Wheel Horse I would appreciate some help on getting the dimensions of the u-shaped pipe/tubing that the headlights attach to.
      I decided that I can make a couple sets for our Lawn Rangers by using conduit and steel plate. I have some chrome headlights that will work with no probelm to the tubing.
      The location of the muffler/exhaust on the tractor suggest the length of the tubing and angle has to be under ten inches to avoid any problem being close to the heat of the muffler and exhaust pipe.
      Any help with this information would be appreciated.
      B)
    • formariz
      By formariz
      Added the first replica HL-5 today on the 653, the first of a couple of dozen in the works. They are not connected yet, working on a bracket for switch.
    • perry
      By perry
      anybody here have a original wheel horse cyclopse light on any of your tractors ?
      got pics ?.
