wheelhorse can do 0 #1 Posted September 19, 2017 Ive got a wheel horse model 265-5 It was a “hand me down” from my brother. I suspect the transmission fluid id either low or needs to be changed. I don’t see a reservoir tank for it. How to I check the level Share this post Link to post Share on other sites
WHX?? 49,177 #2 Posted September 19, 2017 Do a search for 265 in the files section (upper right hand corner use the pull down for files) and find the manual for your tractor. It should be in there. Problems use your shout out. BTW Share this post Link to post Share on other sites
stevasaurus 22,872 #3 Posted September 19, 2017 Do you know what year it is?? I did not find any thing on a 265-5. Most, if not all, of the 200 series used the Peerless transmission. Some of those are packed with grease and are considered not serviceable. If no one comes in here with information, your horse is new enough that I would call my TORO dealer. If you know what model Perless you have...we do have transmission manuals in the manuals section on the main page. You should have a tag on the transmission. BTW...Welcome to Red Square. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,102 #5 Posted September 20, 2017 Some info on the 265-6 made 1996-2000 using 3 different model numbers. Tractor serial number will identify the year. All used the 820-024 Peerless transmission. Garry 1 Share this post Link to post Share on other sites
953 nut 55,849 #6 Posted September 20, 2017 18 hours ago, stevasaurus said: Peerless transmission. Some of those are packed with grease and are considered not serviceable. A couple of decades back (before I owned a ) I had an MTD with a grease packed Peerless. I had to replace one of the gears after three years because it seized to the shaft (lack of lubrication,imagine that). When I put it together I filled it half way with 80W90 gear oil and had no further problems with it, passed it on to my son and he sold it after using it a dozen or so years. 2 Share this post Link to post Share on other sites
wheelhorse can do 0 #7 Posted September 20, 2017 Thx all for the guidance I'm new to the forum and put in the wrong Toro Model. It's a 265-6. 72045. 1996 I believe. From what I could read on the file I downloaded it's a Peerless transmission. Runs great but sloooow going uphill. Any ideas? Share this post Link to post Share on other sites
WHX?? 49,177 #8 Posted September 20, 2017 Check the belt & tension, also the motion control linkage. Share this post Link to post Share on other sites
