CountryRock 199 #1 Posted September 17, 2017 I've been mowing most of the season with this rig and it's been a great little tractor. New belts, spark plugs, oil/filter, air filter, led headlights and assorted deck parts were installed. I cleaned all the debris that was packed around the cylinder heads. About a month ago I found a 244-H parts rig and it had the right size deck to replace my ratty one. A little bit newer model deck, but it fits. Had to weld up a few cracks on it, a little fresh paint and transfer the new parts from the old deck to the new one. I just tested it out and it's perfect. Could not be happier. I'll be finishing out the season with it in its current shape. Next spring I'll be getting new tires and a new pto clutch for it 5 3 Share this post Link to post Share on other sites
Red144runner 658 #2 Posted September 17, 2017 Tough looking tractor 1 Share this post Link to post Share on other sites
squonk 41,691 #3 Posted September 17, 2017 you'd be surprised what those 200 series tractors are capable of! 2 Share this post Link to post Share on other sites
muz123 1,192 #4 Posted September 17, 2017 Thats one sharp looking 200 series!! Love it! 1 Share this post Link to post Share on other sites
WHX?? 49,535 #5 Posted September 18, 2017 Welcome to the 246H club. Probably just you and I are members tho! While it's not exactly a bucket list tractor by any stretch a nice mower all around and very dependable if taken car of. Briggs twin 18 hp. has plenty of power and always starts easy. Manuals can be found here if you don't have them. a few shots of mine. 2 2 Share this post Link to post Share on other sites
CountryRock 199 #6 Posted September 18, 2017 On 9/18/2017 at 6:40 PM, WHX12 said: Welcome to the 246H club. Probably just you and I are members tho! While it's not exactly a bucket list tractor by any stretch a nice mower all around and very dependable if taken car of. Briggs twin 18 hp. has plenty of power and always starts easy. Manuals can be found here if you don't have them. a few shots of mine. Thanks. I got all the manuals back in May when I got the tractor. That should be 16hp, not 18hp 1 Share this post Link to post Share on other sites
WHX?? 49,535 #7 Posted September 18, 2017 My bad I've, only owned it for 20 years! I meant to say it performs like an 18! 2 Share this post Link to post Share on other sites
CountryRock 199 #8 Posted September 18, 2017 Yea, quite an impressive little power plant. Share this post Link to post Share on other sites
Vinylguy 4,688 #9 Posted November 28, 2017 I need a 246-H owner to test out this kit for me. I know they are not real popular for collectors but I have had requests a couple times a year for these. I finally was able to get the artwork done for this hood.I will gladly send this kit to someone willing to test for fit. Biggest concern is the front decal to see if I have the proper positioning for the headlights. 1 1 Share this post Link to post Share on other sites
DennisThornton 4,769 #10 Posted December 1, 2017 Don't get no respect! But at least some should! 1 Share this post Link to post Share on other sites
DennisThornton 4,769 #11 Posted December 7, 2017 @Vinylguy What can I do to help? Share this post Link to post Share on other sites
WHX?? 49,535 #12 Posted December 7, 2017 Did you ever get someone to test it out for you Terry? I can but my orginals are in pretty decent shape. Share this post Link to post Share on other sites
CountryRock 199 #13 Posted April 1, 2018 I fired the tractor up today after sitting in the garage all winter. Started right up with no issues. Put all new viton fuel lines on it in the fall. Going to check and adjust the valve clearance on it, replace the tires and the pto clutch very soon. I ordered the xtreme outdoor power equipment clutch today. Tires will likely be ordered in a few weeks. I also need to fix the steering on it as there is a ton of slop. I'll be pulling the steering shaft and other parts from a 244H I picked up for parts last august. Looking forward to mowing season. 2 Share this post Link to post Share on other sites
Vinylguy 4,688 #14 Posted April 1, 2018 (edited) On 12/7/2017 at 12:20 PM, WHX16 said: Did you ever get someone to test it out for you Terry? I can but my orginals are in pretty decent shape. Sorry I missed you post about this. I did get a front headlight panel and Made a template but the clearances are so close around the huge headlight lenses that it is difficult if not impossible to align this decal perfectly. In fact the original decal on my headlight bezel was far from positioned perfectly from the factory. Might be easier to trim out the headlights after installing the decal. Edited April 1, 2018 by Vinylguy 1 1 Share this post Link to post Share on other sites
CountryRock 199 #15 Posted May 6, 2018 Ok, this will be a bit of a long post. Back in April I discovered I needed to do headwork on this right when I went to adjust the valves on it while readying it for mowing. Exhaust guide on cylinder 1 walked out enough to smash the pushrod. I reset the exhaust guides on both heads, lapped the valves and put it together with new gaskets all around. Runs like a clock now. In the past weekend I installed new Carlisle tires and a new Xtreme outdoor power equipment PTO clutch. Greased everything up and ran it around the yard a little while ago. It's good to be mowing again after the garbage winter we had. Enjoy a few pics. 1 2 Share this post Link to post Share on other sites
WHX?? 49,535 #16 Posted May 7, 2018 (edited) I got that same clutch for my 246 ...runs great, smooth engage and quiet..Make sure you follow Xtreme instructions and call them if you got issues ...very good customer service. Way over underrated tractor as far as I'm concerned. One of my main mowers. 600 + hours on the Briggs and never fails me. Tires look nice! Edited May 7, 2018 by WHX17 1 Share this post Link to post Share on other sites
CountryRock 199 #17 Posted May 7, 2018 About 650 hours on this one. The clutch does seem quite smooth. I imagine it will get better as I use it. Share this post Link to post Share on other sites
Sparky-(Admin) 21,568 #18 Posted May 7, 2018 So I gotta ask....what is that next to the starter that looks like a birds nest? And what's right above the exhaust in your pic? Share this post Link to post Share on other sites
CountryRock 199 #19 Posted May 7, 2018 On 5/7/2018 at 3:17 AM, Sparky said: So I gotta ask....what is that next to the starter that looks like a birds nest? And what's right above the exhaust in your pic? That is some heat-proof fabric that is wrapped around the fuel lines and some wiring. Share this post Link to post Share on other sites
CountryRock 199 #20 Posted May 9, 2018 Did the first mostly full mowing with it today. I could tell right off that it performs much better in the longer grass with the new clutch. No bogging down like it did with the old one. Very pleased with that. 1 Share this post Link to post Share on other sites
WHX?? 49,535 #21 Posted May 9, 2018 Yes and engagement is much smoother. On 5/7/2018 at 3:35 AM, CountryRock said: That is some heat-proof fabric that is wrapped around the fuel lines and some wiring. Mine doesn't have any thing in that area like yours. Have to get some pics Share this post Link to post Share on other sites
CountryRock 199 #22 Posted May 9, 2018 Added the fabric ourselves. Mainly on the fuel lines. The only wires there are the voltage regulator wires and pto clutch wire. Share this post Link to post Share on other sites
CountryRock 199 #23 Posted May 10, 2018 On 5/9/2018 at 7:17 PM, WHX17 said: Mine doesn't have any thing in that area like yours. Have to get some pics Here's a close up. Share this post Link to post Share on other sites
Vinylguy 4,688 #24 Posted February 11, 2019 Got a 246-H headlight bezel from A-Ztractor After several tests and adjustments to the template I have been able to complete the 1990 246 hood sets. Even though the vertical shaft tractors are not popular for restoring I have had a few requests. This is everything I have for the 246-H so far 1 1 Share this post Link to post Share on other sites
Mdunfeeyj 0 #25 Posted September 18, 2019 Anyone have issues with voltage regulator on the 246H. My voltage meter is reading high for the last two weeks and yesterday my pto went out . No reading with ohm meter, also seams as if my pto switch also went bad at the same time no voltage at the plug but battery voltage is good and regulator lets it go high at times pretty much pegging the on board meter at times. I shut it down when it gets high so I dont ruin the battery. Thought maybe it caused the pto to smoke not sure how sensitive they are . Share this post Link to post Share on other sites
