WheelHorse-fan 3 #1 Posted August 31, 2017 I have been given a Wheel horse but not too sure what model it is If anyone could help identify what model and year it is that would be great I have attached some pics 1 Share this post Link to post Share on other sites
953 nut 57,904 #2 Posted August 31, 2017 You have a 1974 Raider 12! Share this post Link to post Share on other sites
Anglo Traction 761 #3 Posted August 31, 2017 (edited) Hi, Yep , as Richard says. However, it was a confusing year in the Belgium Assembly Plant with naming Tractors. I have the same Model number and it originally had some cheap old stickers quoting Raider 12 !. I chose to re decal mine to a C-120 to follow Toro's records. If you type 1-0353 into this Link, it will give you the Illustrated Parts List (IPL). So in 74, there are 12hp Tractors labelled as Raider12, 12HP 8 Speed and C-120 !. If you want to see what I had done with mine, here is a Link to the rebuild topic- Rebuild . Hope yours is in much better condition than mine was. If you need any help with it, just ask. Good luck with whatever you plan to do with it. . Edited August 31, 2017 by Anglo Traction 2 Share this post Link to post Share on other sites
WheelHorse-fan 3 #4 Posted August 31, 2017 Thanks for the information the links are very useful. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,243 #5 Posted August 31, 2017 Click above the red bar Garry 1 Share this post Link to post Share on other sites
meadowfield 2,651 #6 Posted August 31, 2017 models with that decal set were typically known as no name 12, despite being the same as the models above. I suspect the blue dymo label is the GD Mountfield serial number as my GT14 has the same label... 2 Share this post Link to post Share on other sites
Anglo Traction 761 #7 Posted August 31, 2017 1 hour ago, meadowfield said: models with that decal set were typically known as no name 12, despite being the same as the models above. I suspect the blue dymo label is the GD Mountfield serial number as my GT14 has the same label... Reckon you could be right about that Mark. I remembered seeing one on mine originally- Maybe GD Mountfield found the old Ali Plates were getting expensive ?- Like the one on my 1972 Raider 12- Share this post Link to post Share on other sites
meadowfield 2,651 #8 Posted August 31, 2017 not sure about expense as my 1979 C-101 and C-121 both had the Ali plates... maybe a size thing? Share this post Link to post Share on other sites
