Searcher60 209 #1 Posted August 29, 2017 (edited) My recently acquired 520H was missing the 9 pin connector when it was delivered. So, I purchased several new 9 pin connectors to replace the missing one on my 520H. The replacement connectors do not seem to have pins that are as substantial as the ones from the original 9 pin plugs. The only information I can find says that these replacement connectors (OEM) are rated for a maximum of 17 amps. The 2 headlights which run thru the 9 pin connectors draw over 4 amps total by themselves. Charging the battery and running the ignition coil, plus headlights and tailites, plus gauges and dash lights, how many amps? Also, I have spoken to Molex. Apparently, they do not make a connector of this style that is rated for more than 20 amps. I know, AMP made the original, but they do not make one either, apparently. Edited August 29, 2017 by Searcher60 1 Share this post Link to post Share on other sites
Achto 28,760 #2 Posted August 29, 2017 (edited) I've looked at the 9 pin on my 520 and see things that I don't like, biggest thing that I don't like is that they are not water tight. The future plan with mine is to change it to a Deutsch connector. These can be obtained for use with 12ga+ wire, plus they are water resistant. A little tip when using a Deutsch connector - instead of buying the special crimper for the pins, I prefer to solder the pins onto the wires. Edited August 29, 2017 by Achto 5 Share this post Link to post Share on other sites
Achto 28,760 #3 Posted August 29, 2017 I believe that this plug combo would suit our 520 9 pin needs quite nicely. https://www.aliexpress.com/item/Deutsch-Connector-J1939-9pin-Connector/32704851404.html?spm=2114.search0304.4.8.ch1zZb 1 Share this post Link to post Share on other sites
rmaynard 15,913 #4 Posted August 29, 2017 The 9-pin connectors that I sell are the same as the OEM'S. They worked fine for 30 years, these should work just as long. 5 Share this post Link to post Share on other sites
Searcher60 209 #5 Posted August 29, 2017 3 hours ago, rmaynard said: The 9-pin connectors that I sell are the same as the OEM'S. They worked fine for 30 years, these should work just as long. I am not out to criticize your parts or you in any way. However, the pins that came with your connectors do not appear to match the pins in the pics in the original connector pictured in the link below. The pins in the pics are a different design, and the pin metal appears much thicker. Check it out and let me know. I just do not want to do the job again. I am mostly concerned about the 2 larger wires and the solenoid wire. No offense intended. Share this post Link to post Share on other sites
N3PUY 1,031 #6 Posted August 29, 2017 I think I got these from eBay. 1 Share this post Link to post Share on other sites
Searcher60 209 #7 Posted August 29, 2017 Does you have your original pins and connector? Share this post Link to post Share on other sites
KC9KAS 4,743 #8 Posted August 29, 2017 4 hours ago, Achto said: I believe that this plug combo would suit our 520 9 pin needs quite nicely. https://www.aliexpress.com/item/Deutsch-Connector-J1939-9pin-Connector/32704851404.html?spm=2114.search0304.4.8.ch1zZb Those connectors look like they would do the trick, and they are reasonably priced even with shipping.....but you better not be in a hurry....12--20 days shipping! Share this post Link to post Share on other sites
rmaynard 15,913 #9 Posted August 30, 2017 It appears as though your 520-H does not have an original plug. I have sold 100's of these plugs and they have always been a direct fit for the original OEM plug. 1 Share this post Link to post Share on other sites
Searcher60 209 #10 Posted August 30, 2017 2 hours ago, rmaynard said: It appears as though your 520-H does not have an original plug. I have sold 100's of these plugs and they have always been a direct fit for the original OEM plug. Do you sell gold or heavy duty pins for these plugs? Share this post Link to post Share on other sites
rmaynard 15,913 #11 Posted August 30, 2017 No, only the OEM style. If you want gold, contact @Cable. He may have some. Share this post Link to post Share on other sites
k2wilson 41 #12 Posted September 13, 2017 A previous owner of my '97 520H used this method to eliminate the 9 pin connector. Not the way I would have done it, but I've had no issues at all with it. 2 Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #13 Posted September 13, 2017 3 hours ago, k2wilson said: A previous owner of my '97 520H used this method to eliminate the 9 pin connector. Not the way I would have done it, but I've had no issues at all with it. That's pretty much what I do except I use "bullet" connectors then taped off to keep out moisture/dust ect, and it also keeps the harness plug and play, Jeff. Share this post Link to post Share on other sites
doc724 925 #14 Posted September 13, 2017 Guys, I don't want to rain on your parade (no pun intended) but moisture is not the primary culprit here. It is heat. Sealed connectors came into widespread use because of low voltage/currents could not break thru the oxide on the connectors. A proper connector has a gas (not gasoline) tight seal at the interface between the two parts. The sliding motion of assembly scrapes the oxide from the connector surface and gives a bare zinc mating surface. For low currents, gold is way better since gold does not oxidize. On the Onan WH applications, that connector sits real close to the rear cylinder and it gets real hot. The heat will cause the connector male/female parts to relax (lose compression) and pretty soon you have none at all. When that happens you will get arcing between the male/female parts and now the connector housing will melt and you have a mess. It is not just an Onan problem. I recently had to replace the connectors to the voltage regulator on my C141. The first sign of trouble was that the connector body was melted. A couple of weeks ago, I peeked under there and i could actually see the sparks jumping between the two terminals. So I bit the bullet and ordered new terminals, connector bodies, and a regulator just for good measure. Of course this machine is almost 40 years old so some failure is expected. Deutsch Connectors are great products. Caterpillar uses them almost exclusively and you know what kind of crappy environments their machines have to work in. Twenty years from now, they may need replacing, but many of us will not be around either 2 Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #15 Posted September 13, 2017 If you look closely at my pic I have my new connections up next to the battery/fuse box area to help with the heat issue as well, but I like to wash my s down and water/moisture will eventually get in the connections, plus the last 2 I rescued were kept outside uncovered, Jeff. Share this post Link to post Share on other sites
doc724 925 #16 Posted September 13, 2017 One of the RS vendors, I think it is Glen Petit, makes covers that go on the fuse blocks to keep out water, grass clippings etc. Share this post Link to post Share on other sites
AMC RULES 37,145 #17 Posted September 14, 2017 Post #3 here... Share this post Link to post Share on other sites
Searcher60 209 #18 Posted September 14, 2017 5 hours ago, doc724 said: Guys, I don't want to rain on your parade (no pun intended) but moisture is not the primary culprit here. It is heat. Sealed connectors came into widespread use because of low voltage/currents could not break thru the oxide on the connectors. A proper connector has a gas (not gasoline) tight seal at the interface between the two parts. The sliding motion of assembly scrapes the oxide from the connector surface and gives a bare zinc mating surface. For low currents, gold is way better since gold does not oxidize. On the Onan WH applications, that connector sits real close to the rear cylinder and it gets real hot. The heat will cause the connector male/female parts to relax (lose compression) and pretty soon you have none at all. When that happens you will get arcing between the male/female parts and now the connector housing will melt and you have a mess. It is not just an Onan problem. I recently had to replace the connectors to the voltage regulator on my C141. The first sign of trouble was that the connector body was melted. A couple of weeks ago, I peeked under there and i could actually see the sparks jumping between the two terminals. So I bit the bullet and ordered new terminals, connector bodies, and a regulator just for good measure. Of course this machine is almost 40 years old so some failure is expected. Deutsch Connectors are great products. Caterpillar uses them almost exclusively and you know what kind of crappy environments their machines have to work in. Twenty years from now, they may need replacing, but many of us will not be around either No disrespect intended. I believe that heat is the main problem here also. However, since only 2-3 of the connections burn, I think the problem may be that the connector is not sized for the load in those 2-3 wires creating the overload and heat from the overload. The only info i could find on the replacement connector that I used was that it was rated for 17 amps. Not sure this is enough as mine is a 20 amp stator. Due to the tractor harness being shorter after the meltdown, I had to relocate the connector up by the fuse box. i believe the heat coming from the engine fan outlet makes the new location even hoter than the old location on the flywheel side next to the relay. I wish there was a substancially heavier duty 9 pin connector. Molex did have a 20 amp, but, I went ahead and used the AMP. Share this post Link to post Share on other sites
billrok 1 #19 Posted November 8, 2018 The absolute best 9 pin connector with leads is available from Mcmaster Carr. Item #9552T91, Item name is: Compact Push-In Signal/Power Connector Set. Also order the Crimp on butt splices with heat shrink tubing: #7949K41. Share this post Link to post Share on other sites
Searcher60 209 #20 Posted November 8, 2018 Sorry, but the 9 amp rating with 16ga. wire will not handle the load in the red wire and possibly a few others in the original harness. Share this post Link to post Share on other sites
cleat 7,005 #21 Posted November 8, 2018 Get the charge wire out of the 9 pin and run it directly to the starter solenoid battery cable with an inline 30A fuse. That gets the heavy current out of the 9 pin. 1 Share this post Link to post Share on other sites
Razorback 1,069 #22 Posted November 8, 2018 2 minutes ago, cleat said: Get the charge wire out of the 9 pin and run it directly to the starter solenoid battery cable with an inline 30A fuse. That gets the heavy current out of the 9 pin. That is a great suggestion! Thank you! Share this post Link to post Share on other sites
kwalshy 237 #23 Posted November 9, 2018 Change headlights to LED, that will cut down amp draw 2 Share this post Link to post Share on other sites
cleat 7,005 #24 Posted November 9, 2018 Yes, once the charge cct is out of the 9 pin then the next highest power user is the headlights so a switch to LED would fix that. After that all you have is the ignition circuit, gauges, indicators etc that really draw very little. You have the start solenoid but that is only in short bursts so that should not create too much heat. Share this post Link to post Share on other sites
squonk 42,513 #25 Posted November 10, 2018 (edited) 5 holI like Polaris connectors. I get a couple of 5 hole inline models for the correct wire size and a little tape. They aren't cheap but easy, safe and weathertite. I just tape down the plugs to secure them. Edited November 10, 2018 by squonk Share this post Link to post Share on other sites
