Socks 2 #1 Posted August 27, 2017 (edited) Edited August 27, 2017 by Socks 1 1 Share this post Link to post Share on other sites
Sparky-(Admin) 22,079 #2 Posted August 27, 2017 Need more info like how does it run? Start easy? Blow smoke? Does the tranny shift thru all gears in both Hi/Low. Charging system work? Tires hold air or not? Are they all dry cracked? Are they original which makes them 36 years old. I see the deck is rusted thru pretty bad and the front edge of the deck is bent in. How does the paint look when it's not freshly sprayed with water like it is in the pics? Need more details. Mike.... Share this post Link to post Share on other sites
N3PUY 1,031 #3 Posted August 27, 2017 looks like a tractor only with a Briggs ..... $150. Share this post Link to post Share on other sites
daveoman1966 3,807 #4 Posted August 28, 2017 It must be this model... 01-11BH01 1982 SB-421 8-Speed Briggs 252417-0245-01 11 Wheel Horse 5086 Share this post Link to post Share on other sites
Socks 2 #5 Posted August 28, 2017 2 hours ago, Sparky said: Need more info like how does it run? Start easy? Blow smoke? Does the tranny shift thru all gears in both Hi/Low. Charging system work? Tires hold air or not? Are they all dry cracked? Are they original which makes them 36 years old. I see the 2 hours ago, Sparky said: Need more info like how does it run? Start easy? Blow smoke? Does the tranny shift thru all gears in both Hi/Low. Charging system work? Tires hold air or not? Are they all dry cracked? Are they original which makes them 36 years old. I see the deck is rusted thru pretty bad and the front edge of the deck is bent in. How does the paint look when it's not freshly sprayed with water like it is in the pics? Need more details. Mike.... is rusted thru pretty bad and the front edge of the deck is bent in. How does the paint look when it's not freshly sprayed with water like it is in the pics? Need more details. Mike.... it is a Briggs & Stratton motor everything runs well works well. Enginestart right up does not smoke headlights do work drove it around in all gears seems good to me in both high and low range tires do show signs of age and should be replaced also picking up snow blower attachment this week on the cheap just thought I may have found a diamond in the rough anything you can do to help me would be appreciated Looking to find A new deck Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,243 #6 Posted August 28, 2017 We do not have a whole lot on this model Tractor 1982 SB-421 8-Speed D&A TIPL SN.pdf Garry Share this post Link to post Share on other sites
Ed Kennell 40,484 #7 Posted August 28, 2017 1982 C -series garden tractor type SB 421 8 speed 11 HP B&S With a better 36" deck, it could be a good mower. IMO, a little underpowered for a blower. The tin looks fairly straight and if everything works as you state, I think it is a $2-300 machine. It is the first one I have seen. Share this post Link to post Share on other sites
