HandCannotErase
Toro 212-5 no electrical power
HandCannotErase
Hello everyone. The other day I picked up a 92 Toro 212-5 lawn tractor with no deck non-running for $30 (MN: 32-12O503). The guy I bought it from said the ignition was left on with the headlights on and killed the battery so it should just need a new one. I made attempts to jump start the tractor, it would get power (the headlights would turn on and clutch would click) but wouldn't crank. I tried jumping the solenoid terminals to see if the starter was good (and it does work, tho I couldn't attempt to start the tractor due to the position of the solenoid terminals I couldn't maintain a good connection). But since doing that I've lost all electrical power on the tractor; absolutely nothing turns on, even with a new battery. Did I short something out? Also when I got the tractor I noticed one of the fuses had melted into the fuse block, so I spliced in some new connectors and fuse (as well as replacing the 2 other fuses). I tested the key switch and thats working fine. All my connections are good.
I'm really stumped, I'm not sure where to go from here. I'm really not the best at figuring out electrical issues. If it was a mechanical issue I'd have had it running the same day I got it.
Edited by HandCannotErase
gwest_ca
This should simplify it
Garry
HandCannotErase
So I looked over the wiring and found the seat switch wires were cut, so spliced them back together. I also took the solenoid off and inspected the terminals and cables, everything looks okay, so I put it all back together. Now whenever I connect the battery the starter continuously spins (but doesn't engage the engine) until I disconnect the negative battery cable (which will arc when I do that).
What on earth is going on??
953 nut
:WRS:      You may have a bad solenoid. Remove the lead that goes to the engine starter and connect the battery cables, turn the key and see if it closes, check the output with a test light to see if it is working.
You will probably find that it isn't getting enough voltage to allow it to go to full speed. Could be the Bendix drive needs to be cleaned up too.
gwest_ca
Disconnect the small wires from the solenoid small terminals and see if the starter still wants to run. If it does the solenoid is shorted internally and requires replacement.
Garry
HandCannotErase
So the solenoid was bad and I found a replacement for $20. It arrived today, I installed it, and it's doing the same thing: running the starter when I connect the battery.
Somewhere the circuit is being completed without the key being on, but it must not be enough to make the starter engage the engine. Like I said above the ignition switch is fine, I tested it and it's working like it should be. I'm really stumped here.
gwest_ca
2 large terminals on the solenoid.
One terminal has a white wire that goes to the battery (+).
The red wire on the other large terminal goes to the starter.
2 small wires on the solenoid.
Black wire grounds the solenoid coil.
Purple wire supplies power only with the key in the start position.
If you leave these 2 wires disconnected what happens when you connect the battery cable?
Garry
  • Excellent 1
ohiofarmer
  It could be that the switch is melted together internally and the start circuit does not disengage. Short work to find this out if you are handy with a multimeter or a test light.
 You mentioned that a fuse block was melted, so the possibility of something like this increases.Even though you tested the switch, is it possible that the PO put on the wrong switch in his attempt to repair it?
Edited by ohiofarmer
  • Similar Content
    • WheelPuke
      By WheelPuke
      I have my 25A fuse blowing every time I put a new one in the slot. The old one was burnt up when I got the tractor put this year. It sat for a year with a dead battery. I stopped using it as much because the transmission is clattering pretty bad when taking off on second or higher. I had to replace the clutch belt a few years ago and couldn't get an OEM. Not sure what is the problem there that's another issue though.
      I have checked the wiring and patched the worn spots where it could be grounding out. The fuse blows as soon as there is power to the system with the ignition off. I'm at a loss of what to check for at this point. Any input from someone who has had this issue would be appreciated. I'm not sure what these units are in the photos but do not know how to test them for a failure. They are directly in loop with the battery and the ignition loom looks to run into that 25A fuse.
    • Redtickuleez
      By Redtickuleez
      Hello gentlemen!!! I recently bought a d180 with loader and backhoe. Im looking for serial number.. there is a plate under the steering wheel but its been pajnted over and i can make it out. Can y'all tell me another location and was this tractor pruchased originally with these attachments and any info would be greatly appreciated... Thanks fellow Wheel Horse enthusiasts !!! !! !!!
    • Aaron Coffman
      By Aaron Coffman
      Hi Red Square Community,
      I am looking into purchasing the below pictured "POND" Walk Away. The unit itself has the cast in “POND” on the chain reduction housing. The two main things I am looking to learn are what value is typical for these to sell for. This one has a Briggs & Stratton model “N” engine. It runs and drives, but the throttle linkage needs some adjusting. It comes with a cultivator and plow implement.
      Secondly, I was wondering if there is any way to determine what year specifically this Pond is from. The seller believes late 1940s and not 1950s. I am new to these machines, so I am looking for some guidance. Thank you in advance!
    • ohiofarmer
      By ohiofarmer
      i know that there is ebb and flow with market conditions, but I have been seeing bargain 520 and c-160 prices more common. I recently saw a c-160 like model on a place other than here that was close by, but i did not get a chance to see it as I was still on a medical tether getting care. i say c-i60 like model because it was a series of numbers like 4455 or somesuch .Tractor had the k series engine clearly a sixteen HP and came with a decent looking deck and pusher blade. i called my buddy Jay and told him for the $250 ask , he better hustle after it. i really do not know if he did.
        I also have been seeing 520s and such lower than I can remember as well as the D series..My theory is that people experiencing paycheck to paycheck living are increasing in number.
      You even are seeing a lot more older trucks like square bodies and especially big blocks than you did before. we used to see this a lot in new trucks when fuel prices hit records.
      i am not claiming expert status on this, but it seems to be trending this way one county next to indiana and 90 miles North of the Ohio River.
       Tell me what you are seeing out there and what you think.
           Edit:  Jay and I ran up to buy Bob Ellison's tractor in MI.  Bob was very nice to deal with and included his "last seat"   I got super lucky buying my first C-160 that did not start and another one shortly dropped in to keep it company. The tractor described above was listed for only two days and was gone
    • Donavon
      By Donavon
      Just curious what is the heaviest for a future project.
