artfull dodger 417 #1 Posted August 26, 2017 I have felt that the Honda push mower muffler set up on my little 6.5hp Yanmar diesel was a bit restrictive. Most folks know that a diesel needs to "breath" to work at its best, both on intake and exhaust side of things. So, at the Portland, IN swap meet, I found this lagged muffler at a vintage Briggs & Stratton parts booth. Picked it up for $25. I shortened up the input pipe and welded up a flanged input set up(Yes I know my bead laying still isn't best, but it holds and seals!). I also made a support mount at the front of the muffler barrel to support the weight. The main barrel is lagged with an outer wrapper, so this helps with heat and the paint/decals above it. The output faces forward, out and down. So I do not get as much fumes as I was with the the original set up I made up. Also a bit quieter as with the original set up, I could tell by the sound of the exhaust, the engine was working against some backpressure due to the smal muffler. I also have a clear lense Tomar Microstrobe to replace the low intensity strobe on the fender now. Still have to mount it up. Mike the Aspie 5 Share this post Link to post Share on other sites
dells68 7,498 #2 Posted August 27, 2017 Looks great!! Very nice setup you made. Don't worry about the aesthetics of your welds. Mine look about the same - what counts is that they hold and serve their function! Very nice looking machine! Share this post Link to post Share on other sites
