charles15
help with c121
charles15
i have a wh c121 tractor and I need new seals for it but I have been having a lot of trouble trying to find them can someone please help me even if u find a place that carries them or a parts manual the idenfaction number is 91-2K801-03738 any help would be highly appricated
SylvanLakeWH
:text-welcomeconfetti:
tunahead72
31 minutes ago, charles15 said:
... the idenfaction number is 91-2K801-03738 ...
That would be 91-12K801 for a 1979 C-121 with an 8-speed transmission.
There should be a parts manual here on RedSquare, set your mouse cursor over "Browse" at the top of this page, and then click "Manuals".  I'll see if I can find one for you, back in a few minutes.
You're looking for transmission seals, correct?
charles15
thank you for your help I found what I was looking for I appricate your help
oliver2-44
go to the transmission forum and there are some post pined to stay at the start of it that cross reference Wh seals to seals you can get at NAPA or a bearing house
953 nut
This PDF will give you all the numbers you could ever want.
UNI DRIVE TRANS 3.pdf
