carlosking450 155 #1 Posted August 14, 2017 Hello everyone, I am repairing the gearbox 5025 of my WHEEL HORSE, the parts are very good, but my doubt is that before separating the two caps of the change notice that the axes had movement from the inside out this is normal or Must adjust? Share this post Link to post Share on other sites
oldlineman 1,482 #2 Posted August 14, 2017 not an expert carlos but I believe a slite in out movement 1/6 to 1/8 inch is normal. One of our transmission guys will correct me if that is not right. 2 Share this post Link to post Share on other sites
pfrederi 17,893 #3 Posted August 14, 2017 In and out movement (1/8") 3mm. is acceptable. There should be no up down or front to rear. 2 Share this post Link to post Share on other sites
carlosking450 155 #4 Posted August 15, 2017 12 hours ago, oldlineman said: I think it must be normal because I do not see anything worn or adjusted to correct that movement. The only thing that could make that movement and depends on the axis is that the lid is ground or that the bearings that are located in the covers are not well In its position Share this post Link to post Share on other sites
Racinbob 11,237 #5 Posted August 15, 2017 In/out movement in the amount mentioned is normal and just the nature of these transmissions. If you're referring to the outer axle bearings they do nothing to stop that movement. Share this post Link to post Share on other sites
carlosking450 155 #6 Posted August 15, 2017 very thanks¡¡ Share this post Link to post Share on other sites
