"hitched" 414-8
By
Heavy Duty, in Restorations, Modifications, & Customizations
Similar Content
By Jayoutdoors
hey there I would like to install a ball and pull my boat and utility tractor around the property. I don't feel as if the design of this drawbar style is built for that not to mention low height. What recommendations, bought or built do you have to help me out..
it would be nice to keep my tiller attachment on if possible.
also what did they use the bar coming from under seat for??
By nylyon-(Admin)
I think I am selling my 1987 414-8 with plow, weights and chains. Now here’s the story on this one. A long long time ago, I was searching for a snow plow for my 416H. In that search I stumbled onto a forum which was one day old. There was no name of the forum, just whtractor.15.forumer.com. Trying to learn more about snow plows I started conversations with one of the active members on the site, let’s call him Mike. Mike convinced me I didn’t need a plow, but an entirely new tractor.
About a week or so later, I found this 414–8 for sale, and bought it. I now had my plow and could plow the driveway. So what happened with Mike @Sparky and this forum I spoke of? It grew a little bit, and we now call it RedSquare, and for sale is one of if not THE reason RedSquare exists today, so you can own a piece of RedSquare history!
About the tractor: 1987 414-8. Kohler M14, runs well does not burn oil. Everything on the tractor works as it should, but it is a worker. The plow is a 48” with a custom made scraper blade, made from heavier stock than original. For the past several years, this has been a dedicated plow tractor, so it hasn’t seen a lot of work, but has also sat outside (under a tractor cover) so lots of let’s say, patina going on.
I a, selling because I just picked up a 416-8, and that will become my winter plow / blower tractor. I am looking for $550, but like I said this tractor is a bit of a legend!
I have cleaned it up since the pictures were taken.
By F. Marra 17
I have a late 80's 414-8. my transmission has a slow oil leak. it leaks slow so its hard to see where it is coming from. i get a small puddle/stain on the floor center under the trans after a few days of non-use. is there a usual problem area that leaks? or is there anyone in the NJ area that can be recommended to repair the trans? I am sure due to its age that gaskets or seals may be shot. the tractor sat for 10+ years at my office on a shelf. It has ran well the past 3 years for me. I would like to fix this leak if possible. Any advice or help is greatly appreciated.
THANK YOU,
Frank
