Similar Content
By D_Mac
Well...... what's too many horses ? Is to many when you have no more room in the garage so you have to start leaving them outside ? You can say you are "tractor heavy " but are you really ? Right @WHX??. I picked this up today. I'm not really a parts buying guy, unless I need them, but I saw this listed and you know. Love at first sight. Appears i just bought a 1969 Charger 10. Or parts of one. PO removed the original tecumseh engine and was going to install this 10hp Kohler. Well as you can see he didnt get far. Engine is on frame not properly secured and nothing else is hooked up. Nothing. Wires hanging all over. Parts off of it. Im not sure if i have everything. I also am unfamiliar with these " newer engines" that dont have the old starter generator. Not sure what works and what dosnt. Just got it home. If you kind fellas can take a look at what i photographed and tell me whats missing or what i will need to attempt to get this thing running again or if I just should rob some parts from it. Wiring it will be very difficult for me. I have said 100Xs I'm a horrible mechanic and even worse electrician. What ever I decide to do with it your opinions will be appreciated. Thanks
By 12 hp Kohler
Been looking at a lot or Raiders and Chargers lately and was wondering if they all have LSD? I know most of them did but I was wondering if some of the later models might have had the Uni drives instead ?
Thanks, Robbie.
By RJ Hamner
I am wondering if there was ever a Service Manual for this particular tractor.
So far all I have found are Owners Manuals (one came with the tractor)
Since this is my first attempt at a HW with a Hydro I am probably going to need all the help I can get
Any help will be appreciated
Bob
By Conner Anderson
I own a Charger 9, it is a 68 and I am wondering what I should ask for it.
I personally want to trade it, just cannot find anything worth my efforts.
I found a younger gentleman in his 20's, he's over 650 miles away from me and he has himself a raider 12, I want it just he wants two tractors for it.
I personally feel my Charger is worth more than 250, as it is one of a kind.
Please, let me know.
By gp2
I just obtained a Charger V7 Automatic. The reservoir is empty and the tranny has no fluid present. There is some residual, so no corrosion appears to be present and the wheels turn freely. I would appreciate input on fluid to use (I believe the manual recommended Wheel Horse #8827 or Texaco Transhydral). Thanks.
