Rollerman
Speedex S??
elcamino/wheelhorse
I like the Speedex, looks in nice shape. What else do you have in your collection ?
Rollerman
I have had several Horse's, but when I moved about 4 years ago, I sold most of my older Horse's for lack of space.
Currently I have 3 worker Horse's, the Homesteader & now the Speedex.
Hoping to find a clean round hood & a Lawn Ranger yet.
Maybe another large frame too.
AMC RULES
    :hilarious:
Off brand slot hitch.
elcamino/wheelhorse
@Rollerman What is a Homesteader , got a picture ?
slim67
Clean Speedex you got. I had one years ago and may have one again someday.
  • Similar Content
    • Team70R
      By Team70R
      Well I scored a gently used Briggs 900 series to repower my new 606! Doesn't have an air cleaner cover for it so I zip tied the filter on after I cleaned all the junk out of the carb and it ran good. Now it will rev slow and die after it idles a second. I'm guessing there's some more gunk in the carb that I either missed or broke free??
    • aHorseofCourse
      By aHorseofCourse
      So I decided to upgrade my 308-8 and do an engine swap.  Main reason being the 8 horse Kohler struggles with the snowblower.  It's a great engine, just not quite enough hp.  Just about every machine I have has a Briggs in it and I've never had a problem with any of them.  So I thought why not drop an opposed twin in the big horse.  After searching for awhile, I found an 18 horse out of a workhorse on eBay.  Had the pto and engine mount I needed on it.  Turned out to be too far gone to rebuild, just flat wore out.  A few months later I got a nearly identical engine off a buddy for free, he was going to scrap it.  Long story short (too late!) I am making one engine out of 2.  The carb, tins, oil pan, and air cleaner housing are off the junk engine. The junk engine was a 1983, the rebuilt one is a 1984.  Parts are very hard to find for this engine anymore, lots of late nights searching eBay.  Model is 422437, splash lube ball bearing 12v electric start horizontal shaft.
      The free engine I started with.  It sat outside for a few years.  After some tinkering and the carb and oil pan off the other engine, she fired right up!
      Disassembly
      The timing pin on both engines was worn, almost sheared off on the junk one.  Briggs only used this for a few years before going to an 1/8inch woodruff key after.  It is very apparent it was a weak point.  Had to drill out the old one.
    • Dan693
      By Dan693
      Inherited this old 2 wheeled tractor.....any help with the manufacturer, year, etc. would be appreciated.
      There are no markings on the frame but the engine is a B&S.
      Pics are fine on my end.....looks like the are upside down and sideways on RS?.....sorry.
      Engine plate.....
      Model   6R6
      Type    105838
      S/N      409307
    • harrythecat1823
      By harrythecat1823
      i need to find out how to figure out how to date my speedex s14. there is a four digit number stamped on the steering hub. I can't find anything else on it. I saw some sites that said there will be a letter in the serial number that will designate the year. mine are all numbers.
