Big_Red_Fred 1,547 #1 Posted August 4, 2017 Before i buy a 953 gas tank that is rusty inside, whats the best remedy to clean out the rust ? Is there a product on market ? Let ole Big Red Fred know Please, i'm starting the resto on 1054, want it to shine like a star filled sky & Growl like a Griz 953, Your Needed ! Share this post Link to post Share on other sites
953 nut 56,325 #2 Posted August 4, 2017 You can pick up a kit that contains a cleaner/rust inhibitor and an epoxy sealer at any good motorcycle shop; cost about $ 50.00. If you have only light rust and no leaks they should be able to sell just a sealer for $ 20.00. Check to get an idea of what is out there. 1 Share this post Link to post Share on other sites
N3PUY 1,031 #3 Posted August 4, 2017 I like to use BBs. Dump in a 1000 or so and shake, shake, shake. They get into tight corners better than nuts and bolts. 1 Share this post Link to post Share on other sites
Big_Red_Fred 1,547 #4 Posted August 4, 2017 Thanks, i just dont wanna be changing filter weekly Share this post Link to post Share on other sites
JPWH 6,149 #5 Posted August 5, 2017 You may want to also look at POR 15 gas tank sealer. I used the sealer in an 854 gas tank and have had no problems so far. Been 1 1/2 years now. I did not use the cleaner and rust inhibitor though. I bought a half pint and had half of it left over. 2 Share this post Link to post Share on other sites
hard worker 1 #6 Posted August 5, 2017 where can i buy cast iron rear wheel weights for my 963 horse Share this post Link to post Share on other sites
953 nut 56,325 #7 Posted August 5, 2017 5 minutes ago, hard worker said: where can i buy cast iron rear wheel weights for my 963 horse Put a wanted ad in our classified section and keep looking on , I got a set there a couple of years ago for $ 150 plus $ 60 shipping. It was the first set I had found in five years. They are a two piece weight that bolts directly to the hub on the inside. 2 Share this post Link to post Share on other sites
