Bttatro
Will a deck from a lawn ranger work on a 606?
Bttatro
The title pretty much sums it up.  I picked up lawn ranger? carcass for $20 in hopes the deck will work on my 606.  It looks like they both use the attach-o-mattic, but I could be wrong.
Any help is appreciated.  Also if anyone needs parts let me know. It doesn't have an engine, fuel tank, hood, front rims, or probably other things too.  (Maybe I should just list what it does have, might be shorter)
Thanks!
Edited by Bttatro
pfrederi
I think you could .  The Lawn ranger deck hangs from 4 flat steel bars that bolt directly to the frame...no tachmatic if the same holes were in the 606 frame you cold use them or drill your own.  You would need to remove the PTO from the 606 as the Ranger  has a  different drive system.  A single belt that goes directly from engine to deck cross shaft, engagement/disengagement is done on the deck itself.  You would also need to find fabricate a belt guard (bent rod) that lets the deck belt disengage similarly to how the tranny belts disengages. It mounhs directly to the engine.
rdeanrj58
Not sure the 4 steel bars would work since the frame on a lawn ranger sits lower than that of a 606
pfrederi
Good point...maybe longer bars???
Bttatro
Thanks everyone.   I took a good close look at it today,  with the help of my son,  20170801_112146.jpg
and decided I'll sell the deck.
Then we went for a ride around the yard and all was good.
  • Similar Content
    • PAguy
      By PAguy
      Hello gents!
      I find myself with a question for the forum before I go down the path of ripping my deck apart in the middle of the season.
      I have a 42 inch rear discharge 78350 that seems to have developed a crack at the center spindle (photo attached). At first I thought I had unbalanced blade issue bc the deck will vibrate something fearce. Long story short took it off got everything sharp and freshly greased. Started it up and it had the vibration again that reverberates through the deck. Now it's not as as bad as before but at the wrong angle or first starting it just vibrates loudly. So looked around and found the crack at the center spindle.
      Debating if a simple weld would be sufficient for this crack or it would need more extensive repair? I don't weld myself but before I bothered the guy that farms the property thought I would ask here for thoughts if someone has had this issue since I was not seeing something in the forum.
      Appreciate your guys help and thoughts.
    • MSBiker
      By MSBiker
      Well it looks like I'm out of luck. I have been looking for blades for my Lawn Ranger and having zero luck. I have tried Wheel Horse part numbers 7908, 7909. Toro part numbers 8777, and 53322 and no one has anything like this. I was thinking about doing a cut down, but finding right hand and left hand blades seems to be the problem.
      Anyone making blades, constructing blades, got a work around, etc? My blades are usable, but that is about it.
    • Brockport Bill
      By Brockport Bill
      48" Mower Deck - Side Discharge model # 78361 -- # 312000163. This mower is listed as being manufactured at the near end of Wheel Horse production for this deck in 2012. This mower is in very good condition used only one season on small yard. Well cared for and stored indoors. The deck has double right side pulley for optional bagger attachment. Any owner who cares for this mower will have a great investment of a classic WH deck to last decades. Cash pick up Poughkeepsie, NY area. No returns. Please send p.m if interested
    • jmack
      By jmack
      What’s the correct v-belt size for a xi drive belt connecting to a 60” deck?
      Just shredded mine today.
    • BrianKoch
      By BrianKoch
      Gentlemen,
      I’m having trouble with getting my deck to raise up and lock and I think it might have to do with the deck being incorrectly set up.
      Based on the picture, does my mower deck look incorrectly positioned? That is, should the pivoting support bar be positioned above or below the wheel support pin?
      Brian
