520-8 gear reduction steering conversion
By
jmdavidh09, in Restorations, Modifications, & Customizations
Similar Content
By Cee245
Finally dug out a complete gear reduction steering from a 520 i had.
Anyone have experience installing these on another model such as 3-400 series? Think the Benefits are that drastic over non gear reduction?
Seems i remember reading on here that it's pretty basic... maybe drilling a couple holes in frame or something? (there are 2 bolts for the steering block on a 3-400 series and 4 for a 520 by looks of it)
I'm not even sure yet what this will go on. Choices are 314-8, , or 416H.
By davem1111
I have this 520-8 that needs some love and restoration expertise, and I don't have the time or gumption to take on this project and give it the TLC it deserves. Local pickup near Bloomington, IN only.... (almost - I might be able to meet somewhere but not too far, and I don't have a trailer.)
The Onan P220 runs, but not well. I repaired the seal on the intake manifold, replaced the carb & spark plugs, adjusted valve clearance, and tried adjusting the governor, but it still surges. It has the swept front axle but does not have reduction steering. As far as I know, all is original, and the hour meter is at 610.
Several attachments could be included in the deal if desired, for a bit extra. Either a 60" SD or 48" SD deck, single stage snowblower, and/or snow plow blade (would need to get extension kit for front wheel clearance).
By DennisThornton
One of the most detailed I've seen.
https://www.homemadetools.net/forum/garden-tractor-loader-videos-85395?utm_source=newsletter&utm_medium=email&utm_campaign=05-21-21&utm_content=05-21-21-181510&fi=181510#post181510
By GEnd
Hi all,
New to the group and hoping to tap into your knowledge. Also hoping I'm posting in the right place. Please excuse me if not.
I live in NE Minnesota, and am looking for a WH tractor for mowing and snowblowing.
I have a couple of questions I'd like your opinion/knowledge on, mostly about snow blowers and steering:
Did all 520H/C models after 1991 have gear reduction steering? How do I know if a machine has gear reduction or not?
Do the newer xi series have gear reduction? I think the 520/2/3xi offered power steering as an option, but do non-power steering models incorporate gear reduction?
I'm leaning toward 2 stage blower, just because it seems heavier duty, and it snows a ton in NE MN. Are the 2 stage units worthwhile?
I was lucky enough to work for Toro for a few years, and really want to find a red machine. Lots of green around here, but hoping to stay RED. Thanks for your help.
Greg
By BMW1
On my D200, when I turn the steering wheel all the way to the left, it has a tight turn radius, but when I turn it all the way to the right, the turn radius is significantly wider.
The tie rods appear to be adjusted evenly.
Anyone have a similar problem and what was done to fix it? The steering does have quite a bit of play, at least 1/4 to 1/2 turn of the wheel.
