jmdavidh09
520-8 gear reduction steering conversion
jmdavidh09
Has anyone converted a 520-8 over to gear reduction steering?
Some questions if you have:
1. Does the motor have to come out?
2. Since the 520-8 has a swept axle, do I just need the lower steering shaft and gear box out of the donor?
3. Anything I am missing or should this be a simple swap?
Thanks in advance!
roadapples
You'll need upper and lower steering shaft. Probably need to pull the engine. At least raise it up some....
littleredrider
Don't have to raise engine. I did mine couple weeks ago and wasn't too bad a job. Need everything from steering column to shaft where tie rods bolt to (can't think of name). I took battery/tray and dash out to install it. Took couple hours, but mine too lil longer cause had to tighten up some free play.
  • Similar Content
    • Cee245
      By Cee245
      Finally dug out a complete gear reduction steering from a 520 i had.
      Anyone have experience installing these on another model such as 3-400 series? Think the Benefits are that drastic over non gear reduction?
      Seems i remember reading on here that it's pretty basic... maybe drilling a couple holes in frame or something? (there are 2 bolts for the steering block on a 3-400 series and 4 for a 520 by looks of it)
      I'm not even sure yet what this will go on. Choices are 314-8, , or 416H.
    • davem1111
      By davem1111
      I have this 520-8 that needs some love and restoration expertise, and I don't have the time or gumption to take on this project and give it the TLC it deserves.  Local pickup near Bloomington, IN only.... (almost - I might be able to meet somewhere but not too far, and I don't have a trailer.)
      The Onan P220 runs, but not well. I repaired the seal on the intake manifold, replaced the carb & spark plugs, adjusted valve clearance, and tried adjusting the governor, but it still surges. It has the swept front axle but does not have reduction steering. As far as I know, all is original, and the hour meter is at 610.
      Several attachments could be included in the deal if desired, for a bit extra. Either a 60" SD or 48" SD deck, single stage snowblower, and/or snow plow blade (would need to get extension kit for front wheel clearance).
    • DennisThornton
      By DennisThornton
      One of the most detailed I've seen.
      https://www.homemadetools.net/forum/garden-tractor-loader-videos-85395?utm_source=newsletter&utm_medium=email&utm_campaign=05-21-21&utm_content=05-21-21-181510&fi=181510#post181510
    • GEnd
      By GEnd
      Hi all,
      New to the group and hoping to tap into your knowledge.  Also hoping I'm posting in the right place.  Please excuse me if not.
      I live in NE Minnesota, and am looking for a WH tractor for mowing and snowblowing.
      I have a couple of questions I'd like your opinion/knowledge on, mostly about snow blowers and steering:
      Did all 520H/C models after 1991 have gear reduction steering?  How do I know if a machine has gear reduction or not?
      Do the newer xi series have gear reduction?  I think the 520/2/3xi offered power steering as an option, but do non-power steering models incorporate gear reduction?
      I'm leaning toward 2 stage blower, just because it seems heavier duty, and it snows a ton in NE MN.  Are the 2 stage units worthwhile?
       I was lucky enough to work for Toro for a few years, and really want to find a red machine.  Lots of green around here, but hoping to stay RED.  Thanks for your help.
      Greg
    • BMW1
      By BMW1
      On my D200, when I turn the steering wheel all the way to the left, it has a tight turn radius, but when I turn it all the way to the right, the turn radius is significantly wider.
      The tie rods appear to be adjusted evenly.
      Anyone have a similar problem and what was done to fix it?  The steering does have quite a bit of play, at least 1/4 to 1/2 turn of the wheel.
