drewd 55 #1 Posted July 29, 2017 I have an old 800 that came with a 2-4300 36" RD mower. This mower used only a Lift Rod that connects the Lift Lever to the Lift Frame. I found a newer deck that looks in good shape (model 5-0721). This deck diagram I downloaded shows it connecting to tractor = Lift Lever to Lift Rod to Lift Bar & Pin. The Lift Bar & Pin connects to the deck Leveler Bar. My tractor does not have and never used a Lift Bar just a Lift Rod (that I still have). Can I hook this newer deck to my Tractor as is? Or do I need to find a Lift Bar & Pin to attach to the Lift Lever? Or another solution? Love the Tractor and I have it running great. Would like to get it back to work on the lawn! Thanks for your help and suggestions! Share this post Link to post Share on other sites
Ed Kennell 38,022 #2 Posted July 29, 2017 I think the newer deck would work fine w/o the lift lever. You will probably have to drill a hole in the center deck carriage bar to connect your existing lift rod. 1 Share this post Link to post Share on other sites
squonk 41,021 #3 Posted July 29, 2017 7 hours ago, Ed Kennell said: I think the newer deck would work fine w/o the lift lever. You will probably have to drill a hole in the center deck carriage bar to connect your existing lift rod. I did exactly that to put a modern deck on my 1276. Share this post Link to post Share on other sites
953 nut 55,069 #4 Posted July 29, 2017 Ed has you covered. Share this post Link to post Share on other sites
ronhatch 406 #6 Posted July 30, 2017 (edited) I eliminated the lift arm assemble when I installed an older (1967?) 42" RD deck on my restored 1979 C-101. No problems. I just attached the lift chain to a bracket I made that mounted to the deck. I'm a believer in simplifying things. I couldn't see the need for the arm. Maybe it's needed for other attachments other then a deck? Plow? Snowblower? Edited July 30, 2017 by ronhatch Share this post Link to post Share on other sites
