fritz 1 #1 Posted February 6, 2009 Hey, WELCOME TO RED SQUARE!!!!!!! sorry if this is off topic but how does rear attached tiller work?? wheres the belt come from??? I have never seen one attached. devin Share this post Link to post Share on other sites
Sparky-(Admin) 21,786 #2 Posted February 6, 2009 Devin. The tiller hangs off the rear of the tractor using the rear axle bracket that a snow-plow hooks into and has cable that ties in with the lift arm to raise it with a helper spring. The engine PTO powers the tiller using a looooong belt and some idler pulleys that mount directly under the PTO. Mike......... PS, I split your question off to keep the wanted section just for wanted stuff. Share this post Link to post Share on other sites
KyBlue 655 #3 Posted February 6, 2009 Okay, here are a couple pictures that I have handy.. If you want to see more, do a Search for Tiller in the Implements and Attachments section, and Im sure you will come up with quite a few different threads that will answer some or most or maybe even all the Questions you might have. These are photos of the Front Idler Setup, photo from behind, showing the mount, my incorrect lift cable setup, and belt routing under the axle. The final picture is the tiller mounted off in the distance. If you Search on YouTube you can find the video of this tiller in action from this spring/Summer. I hope this helps ya out Share this post Link to post Share on other sites
