allen9878
Ag Tires - What Size Can I go up to? (312-8)
allen9878
I have a 1985 Wheel Horse 312-8 and am going to be using it for mudding and other fun stuff. I want to put some ag tires on it, but am hoping any of you can chime in on good places to get them from, what size I can go up to without modifying the fender and such.
Thoughts? Thanks!!!
-Bert
Achto
23x10.50-12 tires will go right on, there will be some side wall bulge because you rims are narrower. You can also go to a 26x12-12 but then I would suggest finding wider rims and you might have some fender clearance issues.
Check Miller tire http://www.millertire.com/categories/lawn-garden-tires/ or shop around for a price that suits you best.
BTW :WRS:
oliver2-44
You might look at some ATV 4 wheeler tires. They seem to run a little less expensive than AG tires
953 nut
:WRS:            23 X 12 ATV tires would be mu suggestion.
Interco Swamp Lite ATV Tire
littleredrider
Check out Interco's blem site. They have swampers and vampires I think for $40-50 each. Im debating on trying a set. Don't remember if they run small or not.....
allen9878
Great feedback!    I'm sure this is a dumb question, but if I buy 23x12x12 atv tires, what do I need to know/look for in a rim? Is there a name for the wheel horse 312-8 bolt pattern/size, and what would be the depth of the rim?  I assume I would either need 10.5x12 or 12x12 for dimensions...
Edited by allen9878
KC9KAS
@allen9878 :text-welcomeconfetti: to :rs:
953 nut
Most garden tractors with 12" rims including :wh: use the same bolt pattern as ford cars, 4.5" bolt circle five lug.
littleredrider
Your gonna need a wide rim to flatten out an ATV tire. Only a couple horses have wide rims, 520s and 1800 series, possibly some others. But cub cadet, John Deere, and sure there are others that use wide rims that share the same bolt pattern. Also look at Jacobson and toro turf mowers, some have 10"'rims. I picked up a set at a junkyard for $40.
Aldon
Pay attention to back spacing as well.
littleredrider
Ah the one thing I forgot to mention. I have a set of 8" wide that came off a cub, when mounted on mine they are real close to the tank/seat bracket, like 1/4"'or so away. The 10" wide ones are on now and they fit like a stock wheel. Adjusting the backspace isn't hard, can move the wheel hub in/pit but only so much.
Achto
You can also use wheel spacers behind the rim if the off set brings the tire too close to the body.
  • Like 4
pfrederi
Remember your 312-8 has an open differential..so when you are in the mud one wheel will spin the other not move.  I put a limited slip in my 310-8 as i got tired of not being able to go up icy hills.  Note both tires are the same size marked on the sidewall Sizes vary by brand,  The smaller ones are deestones the larger Carlisle
  • Similar Content
    • MainelyWheelhorse
      By MainelyWheelhorse
      Hi All, I’m a member of the RedSquare Facebook group, some of you may have seen My tractor there. I have a 1992 312-8 with a 37 inch deck. It came with a house my brother bought, and was given to me. It needed work but just minor things. I mow my lawn with it, and I just bought a plow to push snow/dirt so it’s a working restoration. It was relatively well taken care of by the previous owners so it really just needed a refresh. Anyway see you around the site!
    • Duramax7man7
      By Duramax7man7
      Very Solid tractor!
      Newer Agro Tires on Rear and Solid Front Turf Tires. Wheel Weights on rear. Fully Swapped Forward Swept axle off of 520h. I ran my 60" Deck on this tractor for over a year with no issues.
      Deck it solid top to bottom with no rot and newer blades. Belt and Pulley are good to go!
      She's just a little dusty and needs a cleaning. Can get a nice Seat a Tractor Supply.
      $1175 OBO   -POOS
      (248) 9for3-8six3four Text or Call. I do not visit this site enough. God Bless.
      NEW SEAT INSTALLED ON THIS TRACTOR! Started it up and ran it for a while yesterday... Forgot how nice this thing is. Tempting to keep it but it's time to send her one her way. GREAT TRACTOR!
    • Jon Paulsen
      By Jon Paulsen
      Inexpensive - Carlisle X Trac ATV Bias Tire - 16x6.50-8 Good quality (I expect) Should look nice with my large rear aggies
      I don't know how much these have been discounted, but I expect anything you find like this from a good brand will be 2X to 3X the price. $45 each at Amazon. This tire is discontinued.
      Rough measurement seems they are about 16" tall and the lugs are about 1/2" deep.
    • PWL216
      By PWL216
      Are there aftermarket front rims available for C Series tractors? I have a 120 and a 160 that need front rims… thx.
    • Wvtroutbum81
      By Wvtroutbum81
      Got my dads 1992 312-8 when he passed
      have a snow plow and 42” deck.
      gathering parts to restore back to new as possible. This is my therapy.
