Walhonding520 25 #51 Posted August 29, 2017 Yes. If I get it right, I can stop the surging with the choke. But if I mow for an hour, it will run fine with out the choke. Share this post Link to post Share on other sites
Walhonding520 25 #52 Posted August 29, 2017 I sprayed some carb cleaner on the choke parts and it leveled out for a second like when I found the intake gasket leak with carb cleaner like suggested above. Share this post Link to post Share on other sites
lynnmor 7,391 #53 Posted August 29, 2017 5 hours ago, WVHillbilly520H said: 96 and newer then my Anniversary is actually by serial number a 97 but it definitely has the accelerator pump I had the Al Gore pump carb on my 97, it is now in a box and an older carb has the engine running fine. Those pump carbs were very lean, cold-blooded and temperamental. 1 Share this post Link to post Share on other sites
Walhonding520 25 #54 Posted August 31, 2017 Using carb cleaner I found the gasket between carb and intake. I read before that The Who carb has to come off. Can I buy that gasket independently or does it only come in a kit? Share this post Link to post Share on other sites
WVHillbilly520H 10,374 #55 Posted August 31, 2017 7 hours ago, Walhonding520 said: Using carb cleaner I found the gasket between carb and intake. I read before that The Who carb has to come off. Can I buy that gasket independently or does it only come in a kit? You can get the carb to intake (base) gasket separately but I still suggest you get a "kit" just for peace of mind, Jeff. Share this post Link to post Share on other sites
