Oil Sandwich adapters for Cooling Hydro and Engine oils
By
DarrellF, in Transmissions and transaxles
Similar Content
By Porkskin
Hello all - New to the site, just brought home an '87 310-8 '86 312-A yesterday. So far, no start, no crank no click. For now please consider what it means when I hold the test switch and see all lamps lit except for the oil lamp which is blinking. Regarding that blinking can someone tell what that should tell me? Any other comments about what to expect form the lamps would be helpful. Page 5 of Tractor_1986_200-300-400_OM_810399R1.pdf mentions the lights but I'm not seeing it addresses what the blinking means in this case. Thanks all!
By Berco
I have an oil leak on my Kohler CH22 in my Toro 522XI (see video). I put in new head gaskets to remedy low compression. Then upon first start i had a large oil leak. It seemed to come from the aft oil seal. So i pulled the engine again and replace the seals. I re-installed the engine again today and the leak is still there. This is the leak now: https://youtu.be/pi382fXVXPQ What could cause it? I did blow out the air line from the fuel pump with compressed air into the crank case to clan out any debris. Could that have caused a leak this bad on the oil pan gasket? or another location? thank you all in advance!
By Horse's ass
I can't seem to locate the oil plug on the transmission/hydro of the C161 auto. Can someone please show me where the heck it is!?!? I would think it was right on the bottom somewhere near the filter but I do not see or feel anything that looks like a oil drain.....
Thanks for your help,
Eric
