DTOM 124 #1 Posted July 18, 2017 I picked up a Kwik Way Loader to put on my 520-8 speed. I'm still trying to get the front mount and the two Brace arms from the seller, but i'm starting to feel it might not happen. So can any of you Kwik way owners help me with the correct measurements for the "Front Mount" and the 2 "Brace Arms" that i need to complete this implement PLEASE... Thank you. 1 Share this post Link to post Share on other sites
Rollerman 290 #2 Posted July 20, 2017 Shouldn't be too hard to fabricate or have made. It just snaps into the front tach a matic & the braces are just tubes flattened on the ends with holes drilled in them to bolt in between the two. I'll see if I can dig mine out for some pictures. 2 Share this post Link to post Share on other sites
DTOM 124 #3 Posted July 22, 2017 Not to hard at all. The manual shows the parts to be built with stock pieces, cut to shape and welded. I'm looking to make a exact reproduction of the originals. My cell number is (860)930-3354 if you would like to verbal the measurements. Thank you. 1 Share this post Link to post Share on other sites
DTOM 124 #4 Posted July 23, 2017 Still looking for some help please. Share this post Link to post Share on other sites
lynnmor 7,463 #5 Posted July 23, 2017 I should be able to help you later this week when I move things around. PM me your contact information if you can wait. Share this post Link to post Share on other sites
DTOM 124 #6 Posted July 23, 2017 The loader is mounted to the sub frame and just sitting there till i can install those items. Any help will be appreciated. Thank you, Jason My email: jlindell@megahvac.com My Cell: (860)930-3354 Share this post Link to post Share on other sites
stevebo-(Moderator) 8,365 #7 Posted July 23, 2017 Oh boy ..... Share this post Link to post Share on other sites
AMC RULES 37,144 #8 Posted July 24, 2017 (edited) Some front mount picts I captured here Jason... from the 2014 big show. Edited July 24, 2017 by AMC RULES 1 Share this post Link to post Share on other sites
DTOM 124 #9 Posted July 26, 2017 I cant be the only one with a 520 with a kwik way loader. Please help Share this post Link to post Share on other sites
lynnmor 7,463 #10 Posted July 27, 2017 (edited) OK, here is a materials list: 2 Side Support Tubes: 1.35" OD, .10 wall thickness, 34" overall length. Ends are flattened at 45 degree angle with 2-3/8" on the short side. Holes are 5/8" from the ends. 2 Side Plates: 1/4" x 5" x 5-1/2" Part is bent 45 degrees at 2-1/4" 2 Inner Side Plates: 1/4" x 2" x 5-1/2" 1 Main Cross Piece: 1/4" x 2" x 2" x 16" angle iron Cut to fit Side Plate angles. 2 Hitch Side Plates: 1/4" x 2" x 3" 2 Hitch Side Plate Supports: 1/4" x 1-1/2" x 1-7/16" Welded to above. 1 Hitch Pin: 5/8" diameter x 7-1/4" long 1 Hitch Pin Support: 1/4" x 3/4" x 5" Welded to Hitch Pin, note location on photo. That should give you a start. I'm sure there will be some questions. Edited July 27, 2017 by lynnmor 1 Share this post Link to post Share on other sites
DTOM 124 #11 Posted July 27, 2017 This is exactly what i was looking for, thank you very much! I will get started on gathering up the material and cutting up those dimensions. Share this post Link to post Share on other sites
lynnmor 7,463 #12 Posted July 27, 2017 1 hour ago, DTOM said: This is exactly what i was looking for, thank you very much! I will get started on gathering up the material and cutting up those dimensions. I changed some quantities, see above. 1 Share this post Link to post Share on other sites
Lost Pup 172 #13 Posted July 27, 2017 Photobucket has my pics currently. I have tried to order up the complete download but I never get the email. Here are a few pics from a fellow member JackC. I have complete build pics as well. I will try to find them. I 1 Share this post Link to post Share on other sites
DTOM 124 #14 Posted July 28, 2017 Thank you for the pictures and measurements. What is the measurement between the two inner and outer plates? Where the brace arms bolts in. I'm guessing 1/2". Share this post Link to post Share on other sites
Lost Pup 172 #15 Posted July 28, 2017 (edited) 11 hours ago, DTOM said: Thank you for the pictures and measurements. What is the measurement between the two inner and outer plates? Where the brace arms bolts in. I'm guessing 1/2". I found the pics. Still a few missing. I have all the dimensions on a note pad. tonight I will check my garage. Here are my build pics in no order. Edited July 28, 2017 by Lost Pup Pics Edit 1 Share this post Link to post Share on other sites
