Furious
42" SD Deck Questions
Furious
I have a '68 Electro 12 and recently purchased a good used '90s 42" deck model 15-42SC01.  The deck is in great shape, new blades, bearings, all new wheels, no rust.  I installed it on the Electro 12 yesterday per the Wheel Horse manual and tried a test cut.  Deck runs fine but cuts uneven side to side.  It's not leaving a strip, just cutting lower.  I haven't been able to determine what side is lower yet, I'll get to that tonight.  Any ideas on how what I can do to get an even cut?  I can post some pictures later tonight and I'll have a better idea of what side is cutting uneven after I hit a strip in the front yard.
Ed Kennell
This problem will probably require many pictures to resolve.
Some suggestions;
Is the deck carriage installed fully in both sides of the attach-a-matic  with the fork hooked on the front rod?
Are the height adjustment wheels the same size?
With the deck removed from the tractor and sitting on a flat surface, do the blade tips all measure the same height from the flat surface?
Does your deck have one or three anti scalp wheels  on the front of the deck?
Furious
Thanks for the reply Ed and I agree, pictures will definitely help.  To answer your questions, it is installed properly in the attach-a-matic, however I noticed that the attach-a-matic hooks do have some wear.  All the wheels are brand new old stock, 2 new 6" adjustment wheels, 3 anti-scalp on the front and 2 on the back.  I will be bringing it into my garage this afternoon and checking level and distances as I've seen suggested on other threads.  I'll let you know what I discover.  One question I do have is that when I installed the blades, I noticed that they are actually "lower" than the deck shell.  That is, if I were to set the deck on the ground without the anti-scalp wheels, the deck would rest on the spindle shafts vice the shell...if that makes sense.  It's not a lot, maybe 1/4" below the shell.
Furious
Update. I got the deck mostly level. I think there are several issues at once here. First, I think the deck is sprung on the discharge side or at least what I think "sprung" means anyway. I took some pipe clamps and pulled the sides in until the top of the deck was level across the width then bolted  1/4" c-channel to the top to hold it in place (my welder died a few months ago). I think that took care of that part. Then it was on to the center pulley which I found was "tilted" forward, probably from over tightening the mule drive belt.  I then hammered that back to level. Unfortunately without a welder I can't really reinforce that so I'm expecting it to give way again. Next, I had to shim each blade individually so that when the deck is installed they're all within 1/8-1/4" of each other. Took about 4 hours and multiple installs and removals but the deck mows pretty well now. I'll need to eventually replace my mid mount hooks because they're fairly worn but at least I can mow without creating unsightly strips. Long post but I wanted to update everyone.  I'll try to post some pics later.
Rollerman
Seems like every 42"SD deck I've owned recently cuts low to the one side.
The deck shells do get tweaked, the later decks had a reinforcement rod around the base & helped make them more rigid.
I've found the height adjustment assembly the biggest culprit in the few I've worked on.
The bushings that hold it on back of the deck become worn, the hardware also gets "tweaked".
Also the bar going across with the wheel on either side can get twisted....I caught myself doing this once trimming around a post.
While creeping backwards I pulled one of the height adjustment wheels into the post (unintentionally) & noticed a difference in the cut afterwards.
Just some other things to look for.
Furious
Yes, I agree, the deck is weak on the discharge side. I bolted the c channel in, next step will be to weld in a reinforcing bar. Seen some pictures so it should be fairly easy. I also purchased some reinforcement plates for where the spindles mount. I'll make sure everything is square and level then weld them in. The shell should be bulletproof then.
  • Similar Content
    • Poppa Phill
      By Poppa Phill
      Ive Got an 88 520 and a 60 inch deck.
      My 522 gave up the ghost and being up here in maine I refused to buy a JD .
      Needing the deck mule with the spring,
      also looking for a soft cab.
      Thanks
    • tpsnowbanks
      By tpsnowbanks
      My double pulley deck drive spindle seized up and shredded the shaft.
      Looking for a replacement assembly.
      My rig is 310-8, 1986ish.
      The deck is 36" rear discharge. Similar vintage but has no identifying tags.
      The drive spindle on this one is front and center, not the older version with the tall spindle near the back.
    • lsc1257
      By lsc1257
      I have a 1996 520H Wheel Horse for sale.  The tractor has just over 800 hours on it.  It comes with a 48 inch deck.  The deck is a 1995 and has over 1,500 hours on it, as it came brand new with my 312-8 that I sold several years ago.  This 520-H has the swept front axle so it can handle a 60 inch deck.  I just replaced the battery and the deck belt this summer.  The engine is a 20HP Onan and it starts right up but requires the full choke.  The transmission is an Eaton 1100-062, hydrostatic.  The deck is in rough shape but the spindles appear to be in good working order.  The right rear tire has some cracking.  The original operator's manual for the 520H is included, as is the original operating and maintenance instructions for the deck, plus the installation instructions for the deck.  Also included is a new PTO belt and several miscellaneous deck wheels and rollers.  Additional pictures available upon request.  Asking $500.
    • BrianKoch
      By BrianKoch
      Gentlemen,
      I’m having trouble with getting my deck to raise up and lock and I think it might have to do with the deck being incorrectly set up.
      Based on the picture, does my mower deck look incorrectly positioned? That is, should the pivoting support bar be positioned above or below the wheel support pin?
      Brian
    • davem1111
      By davem1111
      I thought I'd circle back and see if I can fix a 42" deck (05-42MS05) that came off of one of my previous tractor purchases. I got the blades off and the bottoms of the spindles look good, and it needs some metal welded on where the wheel height adustment bracket bolts on. No big deal.
      The problem I'm having now on this deck is that I can't get this one spindle off. I haven't gotten the others off either, but they seem to be fine. This pulley is flopping around and obviously needs help. I've tried heating it with a torch after spraying it with penetrating spray numerous times, and it won't budge.  At this point, I'm thinking that I'll just need to grind it off, right through the spindle shaft, unless I can successfully cut through the thick ring without damaging the spindle shaft. If I have to grind through the pulley, it probably doesn't matter because I think it's shot already. Anyone have any other ideas?
      One question:  Is that thick ring supposed to be part of the pulley? This one is detached and the pulley spins freely (and sloppily).  Assuming I'll need to buy a new pulley, but was hoping not to have to buy another spindle shaft also. I did take the grease zirk off and have hammered on the top some, but only with a block of brass in between. It could already be damaged there.
      The picture doesn't help much, but here it is:
