fast88pu 3,325 #1 Posted July 12, 2017 I am building up a 520 for pulling. It will be a modified puller. 1 1/8" 8 speed rearend. Straight front axle with drop spindles. 26x12x12 rear tires. Skinny fronts and a V twin. Scouting all the pieces now. Got a 8 speed parts tractor last night. 11 1 Share this post Link to post Share on other sites
N3PUY 1,031 #2 Posted July 12, 2017 Parts tractor????? That looks like something I'ld be using! 4 Share this post Link to post Share on other sites
fast88pu 3,325 #3 Posted July 12, 2017 On 7/12/2017 at 7:10 PM, N3PUY said: Parts tractor????? That looks like something I'ld be using! It doesn't look bad. But was rode hard and put away wet many times. Many welds and all safetys removed. The gas tank and seat also caught fire. 7 1 1 Share this post Link to post Share on other sites
AMC RULES 37,144 #4 Posted July 13, 2017 Wonder, you gonna paint that... on the hood Kyle? 1 Share this post Link to post Share on other sites
fast88pu 3,325 #5 Posted July 13, 2017 On 7/13/2017 at 12:06 AM, AMC RULES said: Wonder, you gonna paint that... on the hood Kyle? No its a family event Share this post Link to post Share on other sites
AMC RULES 37,144 #6 Posted July 13, 2017 You mean like this... is a family forum? 1 Share this post Link to post Share on other sites
RandyLittrell 3,894 #7 Posted July 13, 2017 What models had the 1 1/8" axles besides the 520? If any? Thanks. Randy Share this post Link to post Share on other sites
roadapples 6,983 #8 Posted July 13, 2017 Most of them since the mid seventies... 2 Share this post Link to post Share on other sites
19richie66 17,560 #9 Posted July 13, 2017 (edited) Interested in how you do your drop spindles. Some pics if you don't mind. Edited July 16, 2017 by 19richie66 1 Share this post Link to post Share on other sites
Spareparts 85 #10 Posted July 14, 2017 Your going to need a longer trailer, once you see how much fun pulling is you will want two of them, maybe more. Share this post Link to post Share on other sites
fast88pu 3,325 #11 Posted July 16, 2017 On 7/14/2017 at 2:11 AM, Spareparts said: Your going to need a longer trailer, once you see how much fun pulling is you will want two of them, maybe more. This will be my second one Share this post Link to post Share on other sites
fast88pu 3,325 #12 Posted July 16, 2017 Got the 520 yesterday. Started making it today. Here are some pics. 9 1 1 Share this post Link to post Share on other sites
fast88pu 3,325 #13 Posted July 20, 2017 Made a little more progress. Now I have to order tires and wheels and an engine. Borrowed my buddy Aldons engine to begin the mock up. 7 Share this post Link to post Share on other sites
Notfishin 64 #14 Posted July 21, 2017 How much HP does that predator have . next question will you run that in the 5000 RPM class ? going watch and see how this turns out . did you redrill new mounting holes for motor. or did at least two holes line up . im curious what size belt you end up with useing on the transmission . Share this post Link to post Share on other sites
fast88pu 3,325 #15 Posted July 21, 2017 The engine is rated at 22hp and it will be turning a 4k or 4500 rpms. As far as the rest I will post as I go 1 Share this post Link to post Share on other sites
82Caddy 851 #16 Posted July 21, 2017 Hopefully you used a coupon for that engine. If not, 629 until the end of the month. http://www.hfqpdb.com/best_coupon/22+HP+(670+CC)+V-TWIN+HORIZONTAL+SHAFT+GAS+ENGINE Share this post Link to post Share on other sites
fast88pu 3,325 #17 Posted July 22, 2017 Did some washing and painting today 8 Share this post Link to post Share on other sites
fast88pu 3,325 #18 Posted July 22, 2017 Repaired the tower today a mounted the tank 4 Share this post Link to post Share on other sites
fast88pu 3,325 #19 Posted July 24, 2017 Tonights spending spree. 5 Share this post Link to post Share on other sites
19richie66 17,560 #20 Posted July 24, 2017 Is that strapped in? Click it or ticket 4 Share this post Link to post Share on other sites
fast88pu 3,325 #21 Posted July 24, 2017 On 7/24/2017 at 10:30 PM, 19richie66 said: Is that strapped in? Click it or ticket Opps 1 Share this post Link to post Share on other sites
82Caddy 851 #22 Posted July 24, 2017 No really, did you use a coupon on that? I’m intrigued how this works out as a pulling machine. Share this post Link to post Share on other sites
fast88pu 3,325 #23 Posted July 24, 2017 Yes I used the coupon on it. Thank you 1 Share this post Link to post Share on other sites
Notfishin 64 #24 Posted July 25, 2017 Looking Good . Share this post Link to post Share on other sites
Spareparts 85 #25 Posted July 27, 2017 Around here we have several pullers using the Preditor engines with good sucess,most are in the Cub's, curious to see how it handles the belt. The pullers that are using the Preditor say it is mostly cost, for the price of building a good strong Kohles they can buy 2 preditor. Plus the lighter weight allows them to adjust their weight placement better. 1 Share this post Link to post Share on other sites
