scott ostrander   35 #1 Posted July 11, 2017 (edited) Can I put the steering gear reduction off a 520 H on my C-195 Edited July 11, 2017 by scott ostrandet Share this post Link to post Share on other sites
WHX??   49,485 #2 Posted July 11, 2017 I would think so with some custom work of course. I have heard of guys using 520 swept front ends for all kinds of custom work. If you do take a crack at it  BTW 3 Share this post Link to post Share on other sites
KC9KAS   4,741 #3 Posted July 11, 2017 @scott ostrandet  to 1 Share this post Link to post Share on other sites
CasualObserver   3,409 #4 Posted July 11, 2017  3 Share this post Link to post Share on other sites
edwroy   138 #5 Posted July 11, 2017 I recently added a 520H steering to my '82 C195. I used the C195 axle with 520H spindles, tie rods (had to be shortened [shortened out of the middle because of left and right thread]). Steering shaft from 520H (had to be shortened to fit) and the vertical shaft from the 520H. The gear box will bolt to the frame(will need to drill two holes) if you get the horizontal shaft the correct length. Measure 2x cut once.  Good luck  Edwroy 4 Share this post Link to post Share on other sites
WHX?? Â Â 49,485 #6 Posted July 12, 2017 Looks good Ed....I like your choice of rubber. Share this post Link to post Share on other sites
