Similar Content
By BrianKoch
Gentlemen,
I am in need of help. While doing yard work with my K301 powered ‘68 Charger 12 it suddenly came to a stop and won’t start again.
My troubleshooting so far:
Fuel:
• stabil/87 and clean
• good flow before and after pump
• carb clean, recently rebuilt, float level correctly set
Compression:
•good? - blows finger off spark plug hole
•good turnover but doesn’t fire off
•piston and cylinders move freely
•valve lash set .008 intake .018 exhaust
•breather assembly correct and recently serviced with new gaskets and filter
•head gasket not broken, head bolts tight, some carbon on head
Spark:
•no spark
•all electrical/ignition components were replaced 1 year ago except voltage regulator
•no loose connections, no grounding connections
•inspected and applied graphite to starter shaft
•changed plug
•12v to coil good
•cleaned points, points wire has continuity
•condenser ground good
•swapped battery, points and wire, plug and wire, coil, and condenser from running K301 (‘69 Charger 12)
•points push rod does push out when turning engine over by hand, but unable to get points timed using multimeter method and timing mark on flywheel
What else should I check/do?
By PWL216
Hi. I have a C121 which starts right up but lacks power. A compression check indicated 30lbs of pressure. I took the head off hoping maybe it’s just a gasket, but I think the cylinder needs to be honed or bored out. Based on the attached pics, is this block still good and would honing fix it?
By Tuneup
So gang, it's Christmas time and my company has extended its forced vacation to two weeks, sucking 7 days of FTO from me. I've got all kinds of things to do for the wifey-poo but what the heck can I do for me?
I've got two K301s so may as well get out the surgical tools and do a b-gearectomy. The C-125 goes first. Restored that back in '17 and so she's got maybe 75 hours on her. It'll be rather painless and the youngster is visiting so can assist in getting that b-itch up onto the bench. She's already been moved to the garage and the old Kawi and its carb parts moved back to the shed while I search for tiny o-rings. Wish me luck and pics to come. Oh, there is no rattle BUT she's always had a minor knock I chalk-up to excessive end play (didn't measure it back then 'cause I'm bad but, dang!, will now).
By Jeff-C175
I put together a replacement for the missing clutch handle today. I like it so much I'm going to make one for my C-175 also!
Now I need to figure out how come it's not staying DISengaged. It EASILY jumps off the detent at the slightest touch. It appears to be a new bracket / lever, judging from the paint on it, but I have not investigated further yet. Wonder if anyone has run into this and solved it?
What is the correct routing for the throttle cable? This just CAN'T be correct! It's right on the cooling fins of the engine, it's done melted the skin off the cable! Maybe it's a replacement cable and simply too short?
If someone could post a pic of the correct routing it would be much appreciated!
While looking that over I noticed some oil 'weepage' at the front of the engine. To me it appears to be concentrated right under the fuel pump. I presume there's a gasket there that may need to be refreshed?
The only other suspect is the valve cover but and that appears to be a little weepy too, but more so the fuel pump.
What say you K301 gurus?
