Similar Content
By Team70R
I'm used to messing with the narrow, rear discharge decks. The deck on my newly acquired C165 doesn't seem to cut evenly with multiple passes. It cuts great with one pass but if I make a second pass the grass is super uneven! What do I need to adjust to make it cut consistently? Here are some pics after 2 passes, in the same direction
By mikekot3
I am replacing with new spindle assemblies of my model 78345 mower deck. I am unable to find in the manual section what the torque needed to preload the pulley to spindle
bearings under the protective covers on top of the mower deck.
I found the torque required for the blades to be 80-120 lb ft in one of the manuals here.
Please advise or tell me which manual it is found in.
Thank you,
Mike
By dlaw90
I'm looking to add a mulching blade to my 42" Rear Discharge (Model 78350). I would like to stack the mulching blade above the regular blade like this (picture is not mine):
I can't find a mulching bladewith the same specs as the Toro blade (Part # 106635).
Length = 14 1/2"
Width = 2"
C.H. Diameter = 3/4"
Thickness = 0.2040"
The Oregon 90-643 G3 Gator blade is close.
Length = 13 7/8"
Width = 2.5"
Thickness = 0.203"
Will the difference in blade length cause any problems? It seems like everything would still be balanced on the spindle and the Toro blade would still allow a full 42" cutting path. Am I missing anything? I have not verified that there is enough spindle length to accept both blades, but it appears this hasn't been an issue for others.
By Zeke98
Hi All,
I'm new to the wheel horse forum. I inherited my Grandfather's 416-H. The deck is showing some holes from rust. Would you suggest I have the deck welded or try to replace the deck with one in better shape? You can see some metal plates in the attached photos. These were a quick fix. It's time for a real one!
I've also included the model number of the deck. I'd appreciate any suggestions about what other model numbers would be compatible with my tractor.
Thanks.
By WH 312-8 Fan
So I've been poking around for a few months looking about buying a rear discharge deck. After the Gettysburg/ Arendtsville show, I found a few decks there but didn't have the cash on me. I had hoped to make more money off my parts tractor by that point. I found a couple of them that were the "reinforced" style. They had round bar stock around the lower edge of the deck. The more I get dead ends on mower decks, the more I feel that perhaps, maybe, a new deck wouldn't be a bad investment. I plan on keeping the tractor for the long haul. The mower decks I've found so far have all needed cosmetic work at the very least and still were going for about $500. There were a couple for $300-$400 but needed work. I don't have the tools or experience to do metal work on the shell. If I bought a used deck, I'd probably tear it down, clean and paint it best I could. Whatever I would do, would probably need redone in a few years. I'm thinking that even if I found a mower deck, I'd still end up sinking $$ into a deck and time to refurb it before next spring.
So, my thought process was, what if I invest in a new deck. coat the underside right off the bat. I wouldn't have to burn time repairing metal and I would "know what I have".
I put in a request to the New Haven Power up in Vermont asking for a shipping quote. Who knows if their website is current. The financing programs they had posted, some were out of date.
My question to the forum is: have any of you gotten this route? Are the reinforced decks still available? Are the new deck shells junk? I this a trap?
I know going through a parts department will usually land a bigger $ bill and I found some references from 2012 on this forum saying that decks weren't available complete anymore. I was hoping to go through a wholegoods/sales department and get a whole deck shipped to me on a pallet LTL truck freight. I'm looking at twice the cost up front but with a financing option. If they come complete, I could be up and running.
Thoughts? I apologize for any incoherence, there's a lot going around my head.
