tsmall07
My mule drive fell apart - 520H
tsmall07
My mule drive fell apart when I was plowing this winter and I grabbed all the parts I saw, but I'm not sure I got everything.  Seems like there should be some spacers or washers to separate the pulleys.  When it goes back together, I'll put a cotter pin through the nut.
groundhog47
Yes a spacer goes between the two pulleys and outer pulley and guard, outer pn 101757 and middle (inner) 101734. The hex nut looks wrong type, parts just calls a hex nut but it has a serrated pattern on back to sorta lock in place Pn 3219-7 (old # 915007)
Edited by groundhog47
tsmall07
Thanks!
Edited by tsmall07
gwest_ca
1/2" long spacer part number 101757 is on the outside between the pulley and cover.
5/8" long spacer part number 101734 is between the pulleys.
Spacer ID needs to slip over 3/4" shaft.
Garry
tsmall07
I think I'm going to try to cut some out of some 3/4" pipe.
Sarge
Actually , those spacers are thin wall tubing - they must fit against the race of the bearing and not interfere with the pulley facing , or it will destroy the pulley . You'll have to measure the largest diameter that will fit the center portion of the bearing race and order the appropriate bushing material or source the spacers from McMaster or similar . Some hardware stores like Ace carry thin walled spacers that could be cut to fit it . I've had to make new ones for the older mules on several of my units due to bearings seizing up and tearing up the bushings ....it's a time consuming project but not all that hard .
Sarge
tsmall07
Yeah, I thought about that later. Maybe I'll try copper pipe. I've got a lathe, so I could always turn down whatever I use. I see people listed part numbers above. Where would I look for those if I wanted to buy them?
groundhog47
Electrical conduit might work, but if have to by a piece dealer would prob be about that price and your spacing is important. If I get to my spares will get ya a measurement, we know ID a slip over/ loose fit 3/4", length is culprit for now!
tsmall07
Someone posted the length above.  They're cheap enough I'll just order some
  • Similar Content
    • Poppa Phill
      By Poppa Phill
      Ive Got an 88 520 and a 60 inch deck.
      My 522 gave up the ghost and being up here in maine I refused to buy a JD .
      Needing the deck mule with the spring,
      also looking for a soft cab.
      Thanks
    • Joe Reese
      By Joe Reese
      60 Inch wheel horse mower deck with no rot. All spindles greased and spin smoothly. Comes with mule pulley guard & deck belt covers and the rare offset front mule. Has standard blades installed. Have brand new gator mulching blades for an additional $50 Great       Joe Reese
    • tpsnowbanks
      By tpsnowbanks
      My double pulley deck drive spindle seized up and shredded the shaft.
      Looking for a replacement assembly.
      My rig is 310-8, 1986ish.
      The deck is 36" rear discharge. Similar vintage but has no identifying tags.
      The drive spindle on this one is front and center, not the older version with the tall spindle near the back.
    • Duramax7man7
      By Duramax7man7
      Very Solid tractor!
      Newer Agro Tires on Rear and Solid Front Turf Tires. Wheel Weights on rear. Fully Swapped Forward Swept axle off of 520h. I ran my 60" Deck on this tractor for over a year with no issues.
      Deck it solid top to bottom with no rot and newer blades. Belt and Pulley are good to go!
      She's just a little dusty and needs a cleaning. Can get a nice Seat a Tractor Supply.
      $1175 OBO   -POOS
      (248) 9for3-8six3four Text or Call. I do not visit this site enough. God Bless.
      NEW SEAT INSTALLED ON THIS TRACTOR! Started it up and ran it for a while yesterday... Forgot how nice this thing is. Tempting to keep it but it's time to send her one her way. GREAT TRACTOR!
