Matt1961
Need gears for my rj
Matt1961
I have a 1961 WH I think rj58 maybe  Suburban 1st and rev. Is fine, no 2 and 3rd goes in but pops out of gear...
gwest_ca
Your tractor was most likely a 1961 model 551 originally.
Garry
Matt1961
O ok
Racinbob
:text-yeahthat: Definitely a 1961 551, The 2 piece transmission case gives it away. What you need is the 3523 gear and possibly the 3424 input gear/shaft. Since you're going to open it up I'd suggest that you do that first so you can inspect things. You can get the 3523 here https://wheelhorsepartsandmore.com/
I'm sure you'll need seals and possibly some bearings and you can get those from him too :)
stevasaurus
Is this the horse you are talking about in the shout box that you need the guard for.  One of our vendors here makes reproductions of the guard.
I thought I had some pictures from Howard @857 horse that show what you can do if you do not have a belt guard.  Those pictures are now being held hostage by Photobucket.  Maybe Howard will see this and put his pictures back in here.  :)
