DennisThornton
Green Vertical Shaft?
DennisThornton
"JD X500 multi-terrain tractor- 25H.P.-Differential lock-wet disk brakes"
I'm itching for some green, maybe so I can talk about them from first hand experience, maybe because some have hydraulic remotes, differential rears, disk brakes and REAL cabs!  It's certainly not because of the green!  Much prefer red and orange!  So here's a picture of a vertical shaft, which for years was a prominent "No!" in my check list for what's a good tractor, but now that my WH 264H has changed my mind, why wouldn't the JD X500 be a good choice?  Not sure what "multi-terrain" means...  Didn't see anything about PS but maybe it does.  (Further review suggests no PS!)  I'm not looking to buy this unit.  No hitch of any kind on this unit and I don't need another mower, but I'm putting more focus on the fact that it's a vertical shaft and thinking "So!"  I'm not asking about the X500 specifically, just that maybe I should be less prejudiced against vertical shafts.
Anyone with first hand experience?  Any reason why a vertical shaft can't be used in a durable GT?  And by the way, why are vertical shaft engines cheaper!
Digger 66
"Multi terrain" means you can cut my lawn too :ychain:
  • Like 6
slammer302
I hear the John Deere X seires are good machines.
WildHorses
I picked up a Z930M John Deere Ztrak this spring with a 25hp kawasaki vertical shaft motor that's got over 2800 hours on what appears to be an original engine. It's a heck of a mower. It's been converted to propane, some say that's easier on the motor than gas, I'm not sure but it runs well still.
Achto
I think that it's because they make more vertical shaft engines than horizontal shafts.
T-Mo
The Deere X500 series are great machines, very capable, and Deere offers an integral hitch, either power or manual depending on the X500 series model.  Vertical shaft tractors usually have a more efficient system for powering the deck, i.e. mower drive belts don't have to be rerouted, but are straight shots to the deck from the engine. Deere uses either Kawasaki commercial grade engines (gas) or Yanmar engines (diesels) in their X series tractors, which are the ones you would want if buying a Deere.
DennisThornton
That's the only answer I've ever gotten but it seems that larger horizontal engines would see more applications and outsell verticals.
EricF
Horizontal engines see more application nowadays in shaft-driven tractors with the engine mounted fore-aft. Good for larger "true GTs" and SCUT/CUT designs with bigger, heavy frames. A lot of it just depends on current design conventions. They all have their pros and cons.
Achto
This would be a thought but then I think about how many more low cost lawn tractors with vertical shafts are sold compared to higher cost lawn tractors. Even most of the now popular zero turn mowers use a vertical shaft engine.
  • Similar Content
    • HyperPete
      By HyperPete
      JD LX-178 with Kawasaki 2 cyl water cooled engine.
      Great shape except for the front hood.  Cracks have been patched, and hinges on the hood itself are broken.  Hood sits fine, just does not open & close properly
      NO DECK!
      Includes (4) John Deere suitcase weights, a John Deere "maintenance kit", and rear chains.
      Well maintained.  Snow blower presently not mounted.
    • charging10
    • Johndeereelfman
      By Johndeereelfman
      My main reason for joining up here is due to the recently acquired Wheel Horse RJ, however for the past 27 years I have been collecting John Deere's. My collection consists mostly of the round fender 110's and 112's, but I do have a couple of flat fender 120's, 140's, and a 110. My biggest goal has finally been accomplished back in 2009, and that was completing the entire round fender collection, meaning I now have all 5 years and all 11 models made throughout the 5 years that these round fender have been produced. I also have numerous attachments and accessories for these old machines as well as all of the tire types, sizes and brands made from 1963 through 1967. They take up a lot of room when it comes to storing them all, but somehow I'm always finding a way to squeeze in another one.
      I don't have pictures of the entire collection yet, and they aren't all restored yet either, but I recently started unloading the garage so that I could update the collection for insurance reasons, so here are some pictures of what I have out currently:
      1963 110
      1964 110
      1965 110
      1966 110
      1966 110H
      1966 112
      1966 112H
      1967 110
      1967 110H
      1967 112
      1967 112H
      Second 1963 110
      Second 1965 110
      Second 1966 110
      Third 1966 110
      Second 1967 110
      1967 60
      1969 60:
      1971 70:
      1973 70
      1974 70
      1970 120
      1970 140H3
      1973 110
