Team70R
42MS02 Deck Not cutting consistently
Team70R
I'm used to messing with the narrow, rear discharge decks. The deck on my newly acquired C165 doesn't seem to cut evenly with multiple passes. It cuts great with one pass but if I make a second pass the grass is super uneven! What do I need to adjust to make it cut consistently? Here are some pics after 2 passes, in the same direction
slammer302
are the deck wheels in good condition? Maybe a pic of the whole deck so we can see what ur working with.
Team70R
They are all there and seem to be sturdy. I'll have to get a pic when I get home
Team70R
Sorry pics are terrible. Best I can do tonight. Has a total of 7 wheels with 2 of those being the adjustable ones on the rear. Am i not using the adjustable wheels and the adjuster knob for the lift handle correctly?
AMC RULES
Edited by AMC RULES
Team70R
3 minutes ago, AMC RULES said:
I don't think it's a uneven blade issue. It cuts even if I make one pass. But if I make I second one it doesn't line up with the first pass. Maybe it's just more noticeable after 1 pass?
AMC RULES
It's definitely got an issue...
could be somethings up with it's mount.
Team70R
One of the spindles is squeaking too so I guess that gives me enough reasons to take it off for a full inspection
daveoman1966
Deck mounted correctly and LOCK IN ? ? ?  If one side isn't locked in, it will run lower than the other.  That is, the deck is TILTED ....
 Make sure it is locked in place ON BOTH SIDES.  Here is a pic or two....
My only other idea is that MAYBE the outside spindle itself is tilted, causing it to cut lower than the other(s).
Team70R
I got to thinking last night and looking at the pics of how it was cutting and I think this is problem! Seems like it is a tilt issue with the deck! I'll have to check the mounts tonight!
Team70R
Well I got the spindles greased up everything seems tight and straight. We got to looking at the deck wheels and I noticed the adjustment bracket is wayyy bent. Hopefully the pics are good enough to show. Now I have to figure out how to straighten it. The detent spring and pin fall out of the respectable retaining hole!
tunahead72
That could definitely be part of the problem.  It's hard to tell from the photos, but is the upper corner of the bracket (to the right in your photos) bent more than the rest of it, like somebody's been banging on it with a LARGE hammer?  And it looks like the bracket itself isn't mounted flush and tight to the deck -- are those two carriage bolts in good shape, or do they need to be tightened or replaced?  Is the deck basically straight where the bracket mounts, or is that area damaged also?
I would also check the large round cross bar that connects the two wheels -- is it basically straight and mounted securely to the deck?
This old thread might help:
An important note:  This thread I just linked was damaged a bit in one of the software conversions that RedSquare went through a bunch of years ago.  TT's first response in particular was cut off, but here's the complete text:
"If it isn't a broken spring on the handle, 80% of the time the selector quadrant gets pushed or bent away from the gauge wheel "channel"/handle.
Remove the quadrant and bend it back to 90 degrees so it fits tight against the channel, or loosen it and slide it tight against. (if it isn't bent)
The other 20% is the square (looks like keystock) stops welded to the gauge wheel cross bar getting worn enough to let the entire gauge wheel assembly push away from the quadrant."
Edited by tunahead72
Team70R
The quadrant is not even bolted on straight. It looks like the carriage bolts have started to pull/tear from the deck. So I'm gonna have to do some reinforcing I think
Racinbob
You nailed it there as far as that bracket goes. Get that sheetmetal straightened out so the bottom of that bracket is parallel with the cross rod, reinforce underneath and you'll be fine. I'm not sure it will fix your uneven mowing though. :)
Team70R
Haha I hope this fixes it!! Not really sure what else it could be :blink:  here's a few more pics I took after we messed with it a little last night. Hard to judge by the pics though
  • Similar Content
    • Poppa Phill
      By Poppa Phill
      Ive Got an 88 520 and a 60 inch deck.
      My 522 gave up the ghost and being up here in maine I refused to buy a JD .
      Needing the deck mule with the spring,
      also looking for a soft cab.
      Thanks
    • tpsnowbanks
      By tpsnowbanks
      My double pulley deck drive spindle seized up and shredded the shaft.
      Looking for a replacement assembly.
      My rig is 310-8, 1986ish.
      The deck is 36" rear discharge. Similar vintage but has no identifying tags.
      The drive spindle on this one is front and center, not the older version with the tall spindle near the back.
    • lsc1257
      By lsc1257
      I have a 1996 520H Wheel Horse for sale.  The tractor has just over 800 hours on it.  It comes with a 48 inch deck.  The deck is a 1995 and has over 1,500 hours on it, as it came brand new with my 312-8 that I sold several years ago.  This 520-H has the swept front axle so it can handle a 60 inch deck.  I just replaced the battery and the deck belt this summer.  The engine is a 20HP Onan and it starts right up but requires the full choke.  The transmission is an Eaton 1100-062, hydrostatic.  The deck is in rough shape but the spindles appear to be in good working order.  The right rear tire has some cracking.  The original operator's manual for the 520H is included, as is the original operating and maintenance instructions for the deck, plus the installation instructions for the deck.  Also included is a new PTO belt and several miscellaneous deck wheels and rollers.  Additional pictures available upon request.  Asking $500.
    • BrianKoch
      By BrianKoch
      Gentlemen,
      I’m having trouble with getting my deck to raise up and lock and I think it might have to do with the deck being incorrectly set up.
      Based on the picture, does my mower deck look incorrectly positioned? That is, should the pivoting support bar be positioned above or below the wheel support pin?
      Brian
    • davem1111
      By davem1111
      I thought I'd circle back and see if I can fix a 42" deck (05-42MS05) that came off of one of my previous tractor purchases. I got the blades off and the bottoms of the spindles look good, and it needs some metal welded on where the wheel height adustment bracket bolts on. No big deal.
      The problem I'm having now on this deck is that I can't get this one spindle off. I haven't gotten the others off either, but they seem to be fine. This pulley is flopping around and obviously needs help. I've tried heating it with a torch after spraying it with penetrating spray numerous times, and it won't budge.  At this point, I'm thinking that I'll just need to grind it off, right through the spindle shaft, unless I can successfully cut through the thick ring without damaging the spindle shaft. If I have to grind through the pulley, it probably doesn't matter because I think it's shot already. Anyone have any other ideas?
      One question:  Is that thick ring supposed to be part of the pulley? This one is detached and the pulley spins freely (and sloppily).  Assuming I'll need to buy a new pulley, but was hoping not to have to buy another spindle shaft also. I did take the grease zirk off and have hammered on the top some, but only with a block of brass in between. It could already be damaged there.
      The picture doesn't help much, but here it is:
