Team70R
C120? Model number help!
Team70R
Just scored what I believe to be a c120. But I'm not sure. It has the 3 speed unidrive, which I know is incorrect. Not sure if it's been swapped or if something else is out of place. It looks the serial number plate was stamped twice!?:think:
Ed Kennell
A m/n 1-0100 should be  1971 Work Horse with a 3speed and a HH80 Tecumseh.
Team70R
Hmm... very odd! It's got a kohler on it haha. Now I'm really confused :huh:
pfrederi
It is a FrankenHorse :P  I have built a couple of those myself  so many WH parts interchange
Ed Kennell
        :text-yeahthat:
             A M/N 1-0600   would be a  1973 D series with an 18HP Kohler and a Sundstrand 90-1137.
Team70R
Hmm it's definitely a FrankenHorse!! 3 speed rear is currently locked in neutral. Won't shift into any gear.. so I'm gonna most likely sell the Kohler off of it.
Racinbob
Nuttin wrong with a Frankenhorse. I'm betting the transmission is an easy fix. You're not all that far from me if you'd like a hand. :)
Team70R
Thanks! I've got the transmission soaking in an array of fluids right now!
  • Similar Content
    • 1st horse
      By 1st horse
      Trying to figure out exactly what I have a friend gave it to me said it was a 1963 8hp Kohler he's right on the engine but I think he is off on the year and I can't find a serial or model number on it I got intending to completely restore it but I really need to identify what I have I would really appreciate any help and advice
    • Chuck14025
      By Chuck14025
      C120, 1974/75
      I added braces and shims to the rear end of the frame to beef up the cracked existing 'frame to transmission bracket'. Now, the parking brake does not engage.
      The shims are about 1/8" and have to stay on.
      Is there a way to adjust the parking brake?
    • JP56
      By JP56
      I purchased what I was told by the seller, to be a "partially restored" 1975 C Series. I have it now for 3 seasons & have concluded that this restoration consisted of replacing a few bolts and repainting it and replacing some of the decals. The seller told me he "screwed up" on the Model Decals when he ordered them, & put the wrong one on it (C120), but did not tell me the correct one that should be on it, and he gave me a 1975 C Series Owners Manual with it. I am wondering if the Model Numbers correlate to the horsepower of the engines. If that is the case, I must have a C100, because mine has the Kohler 10 HP engine, which is labeled as a K241S. It has an 8 Speed Manual Transmission.
      After getting it home and using it, I put it in my shed & the next time I went to use it, I see the transmission/gearbox has leaked oil onto the shed floor, appears to be coming from the seam between the two halves of the rear-end. I also see a heavy black greasy film build up at both axle seals & also around the brake drum seal. I am now in doubt of the recommended oil for the rear end. Some of the online forums say that they had begun using transmission fluid as a replacement for older types of lubes, while others say 10-30 motor oil. I saw someplace which I can't seem to find again right now, that 85W-140 gear lube was what should be used. The oil level on the dipstick has not dropped to low levels, and appears to be motor oil, so after searching around and also checking the manual given to me with the tractor, I top off the level with 10W-30 as spec'd on page 5 of the manual(if this is indeed the right manual for my year and model).
      My problem now, is that last season, it suddenly seemed to get a bit sluggish & slow down as it gets warmer during use. I believe my sluggishness problem might be due to the leak in the box seam and possibly also the type of fluid/lube in the case of the transmission/gearbox. I had already tweaked the carb as best I could, changed the fuel filter, replaced the spark plug due to a hard starting condition and rough running, & it seems to be running fine right now except for a backfire when shutting it down. I have purchased a replacement carb for it that I have to put on now, & I am pretty sure I need to locate & change the points as well.
      Anyway I am hoping that someone can point me towards the right manuals, by placing all numbers I have been able to find on it here so I can hopefully find the right service/repair manuals (hopefully as free downloads someplace online) for the different systems.
      Tractor:
      Model: 103909
      Serial Number: 47404
      Engine:
      Model: K241S
      Specs: 46636D
      S/N: 6097616
      Deck: 0542M505
      All Numbers on Transmission/Gearbox Casting:
      A24
      8163 or B163 ?(Cannot Read Clearly)
      101761 or 1017G1 ?(Cannot Read Clearly)
      Any and all advice/info anyone can supply me with on this would be greatly appreciated! Also, any tips on good places to purchase reasonably priced parts would be good as well.
    • The Gman
      By The Gman
      Finished up work on the A800 ranger. Time to figure out the c120.
      The ranger got;
      Complete rewire. 👍
      New points.👍
      Re-timed and a new head gasket.👍
      Carb rebuild. 👍
      Full service. 👍
      My daughter is gonna use it this year. She has just under 1/2 an acre to cut.
      Now the challenge is the c120. Picked this up in Jan. Price was right and I was really just after the motor but the rest of it just had to come home too. Not sure if it's all there but the fun will be in finding out. So far I figure a broken clutch pedal and one rotted tire. The po had already taken it apart to restore but other things got in the way. The motor is stout and roars like a tiger.
      I'm  gonna put it all back together first...... fix what I find then tear down to restore.
      It's the transmission I don't know about. Po said it works fine......... Hmmmmm.
      Don't know much about them at the moment but "forum" research ans help here I come!!!
      Transaxle oil is low but clean and the tow valve doesn't look like it's been loosened for a while. The frame sat outside for a year.
      Thought I might change the oil and run it with an electric motor to see?????
      The axles are free and smooth.
      Anything I should be careful of?????
    • The Gman
      By The Gman
      Help time please....
      The k301 for my c120 (bought the tractor literally in pieces but all there I think???? ) is missing the fuel pump. I've check the engine out with the ol  intravenous method and its . Ebay will sell you one for anywhere from $20 - $160. I know you get what you pay for but....... really?????
      Isave tractors has one in the $50 range. Any experience with the plethora  (is that really a word??) of 301 pumps out there?
