12 hp Kohler
D-200 value
12 hp Kohler
How much do you guys think this d-200 is worth I have an opportunity to buy it but not sure what it is worth ? IMG_1299.PNG.605bc0b0a6c6bf1492dce6b97c0b0c01.PNG
elcamino/wheelhorse
Got any other pictures , hard to say what the value is with only one picture.Do you know the year it was made?
pfrederi
No Gas tank I assume it doesn't run.  May have a rear PTO looks like the big pulley behind the grill.  I wouldn't pay much for a non running D series.  if it is an engine problem parts are getting pricey and hard to come by.  Hydro issue can mean a fair amount of work and parts there are pricey also.
If it has a rear PTO and 3 point and turning brakes there  is some money in parting it out.  But that would be about my limit buying it for parts.  400-500
953 nut
If it is non-running Paul is being very generous, if you don't plan on parting it out it would probably be a money pit. If it runs well and the drive train is functioning properly the you need to know what extras it has going for it.
pacer
I Bought this 200 about a year ago --- not running, gas tank rotten, no exhaust, sad seat, slop in steering --- and of course several other small things that were to be found later. The way its sitting in the pic I had cobbled together a fuel source just to see what I had. The motor started right off once all the fuel system was replaced/cleaned ---- BUT! it smoked like crazy! as bad as I have ever seen one smoke! but it was quiet, no knocking. So motor rebuild right off the bat:-o Getting it running allowed me to check out the drive system and it checked great! The deck seemed to be good also. Tires were marginal.
I paid $400 and I was very leery going that much, but I have a weakness for the D's so ....
As it turned out, it was a good tractor, with less headache than I at first thought, the motor was a pain to get parts, but in the end I got them and it now runs like a new one. I estimate I put some $600-800 getting it in decent shape, and that doesnt count a hundred plus hours work.
So It pretty much comes down to "how bad do you want it??" and how skilled are you at getting back into decent condition?
  • Like 4
12 hp Kohler
Ok, sadly I only have the one picture and I don't know the year but it does have a gas tank it is just off on the picture it does have a three point hitch and I a, pretty sure a rear pro but I would have to go and look at it, I will see if I can get it for $250
Then I can't go wrong unless it has a blown engine
:wacko:
953 nut
The engine appears to be a Kohler twin so it would be a '75 or earlier.
12 hp Kohler
Ok, I am waiting for the guy to reply to see if he would do $250, he is slow at replying so it might be a while, I will let you guys know what happens. If I get it I want to get it before the big show so I can get some parts there.
  • Similar Content
    • BuffaloD200
      By BuffaloD200
      '74 D-180
      My friction disc in gone on my clutch.  I saw the old post about making a new friction disc, so I'm not concerned about that.
      I managed to remove the front clutch plate and double v-belt pulley.  But I can't separate the two.  When I took the assembly off the spiraloc washer popped off on its own.  I HAVE READ THE MANUALS.
      So I should be able to just remove the pulley from the front clutch and continue with step 4.  The v-belt pulley is loose as all hell and flops around like a dead fish.  It seems to be hung up on a ring or bearing race.
      So my thoughts are grab a BFH or sparky the blue tip wrench.
      Is there an unpublished step 3.5, or some trick?
    • Stigian
      By Stigian
      A long long time ago there was a thread here about which wheel horse would be on your "wanted hit list".
      One of them was a GT-14 which thanks to Neil, one came my way.. A great machine which has now moved to pastures new..
      The other I'm sure you can guess from the title was a D-200
      Nigel bought this machine from Harry with the thought of changing the engine (which had a knock according to the bloke Harry bought it from), to something a bit different..
      Then Nigel made the mistake of saying something along the lines of "I expect you will end up owning the D eventually".    Which got me thinking
      A bit of a play with the wiring  (The PTO switch had been badly by-passed) and the engine had a spark, and a temporary gravity fed fuel tank sorted out the fuel side of things..
      Much to Nigel and my surprise the engine fired right up and sounded good with sign of any knocking sounds!
      The trans is a bit noisy but that may sort it's self out with a bit of use as the Big D hadn't been used in a very long time..
      A few photo's for you..
      And of course a video.... I hope to get an engine running and driving vid edited today, but for now here's an intro vid..
      The D gets better each time she is driven. The engine always starts first time every time
      Speaking of the engine, a new vacum fuel pump was fitted so I could get rid of the "tank on a plank" that was clamped on the front and use the D's original tank..
      The engine was also missing a cover, so I quickly folded one up from a bit of sheet steel.. Not pretty but does the job.
      The D's first official duty, carting some steel panels up from the scrap pile
    • Noobwheelhorseguy
      By Noobwheelhorseguy
      Howdy everyone,
      Im new to tractor restoration and my first restoration project i want to do is my Wheel Horse D-200. I have no clue where to start on the project and was wondering if any of you had any pointers for a beginner restorer.
       The picture is my D-200 as it sits now more or less.
    • Texas Todd
      By Texas Todd
      So I get the tilt cylinders rebuilt and want to see what I can lift. So I get the D loaded to go to up to my land.
      Got some sizable rocks moved.
      I got this one moved and then put on the rear blade to get some ballast. I could use some more weight and I am looking for ways to do that.
      After about 45 minutes, the transmission seemed to lose it's power.  Where it would spin the tires trying to dig under this first rock, it didn't afterwards.  Though not an emergency at this time, the lifting is the most important and it seemed to transport them fine.  My question is this. I have another transmission from a D-180 (although it may have the same issue, I don't know). Should I swap the trannys like I did the engines or rebuild the transmission that is on it?  Will rebuilding fix this issue?
      I haven't looked to see how these are attached, but are they as straightforward as the C tractors transmissions?
      Thanks for your input!
      I most likely won't attempt it anytime soon, just wanted to get the wisdom of the group.
    • stevieb
      By stevieb
      Hi
      I have a 1978 D200 wheelhorse powered by a Kohler twin cylinder engine
      It is used for grass cutting and has a 48inch cutting deck
      The manual PTO clutch is shot and I would like to fit an electric one
      Any ideas where to source a suitable one?
      Thanks
      Steve
