Tgtack
Camping at show
Tgtack
Anyone know if they allow campfires in the camping area at the show?
stevebo
Yes they do. Bring your own wood as you will not find any in the trail in the woods.
rmaynard
You will also need a fire ring. We were told several years ago that fires are no longer allowed on the ground.
WHX??
Forget the worry Tg...just introduce yourself to Brian (Buckrancher) and make some friends...I'm pretty sure he will  have a nice fire to enjoy! :)
You may have to put up with @squonk tho! :ychain:
Tgtack
Thanks, fire ring suggestion?
benji756
depending on how big you want it you can cut the center out of a old steel rim.
squonk
I'll be chewin the fat under the lights in Chambersburg. :)
Zeek
I use a an old truck rim like this one. I have two. They sat outside for 25 years and never rust out, they are too thick. Plus you can stack them if you want.
The only place I have seen fire rings used is in the wooded area where tents (and buckranchers rig) usually are. I have never seen one used where the campers park (where the power pedestals are), so make sure you pick the right location when you arrive if that is your plan.
