Tgtack 779 #1 Posted June 16, 2017 Anyone know if they allow campfires in the camping area at the show? Share this post Link to post Share on other sites
stevebo-(Moderator) 8,374 #2 Posted June 16, 2017 Yes they do. Bring your own wood as you will not find any in the trail in the woods. 1 Share this post Link to post Share on other sites
rmaynard 15,799 #3 Posted June 16, 2017 You will also need a fire ring. We were told several years ago that fires are no longer allowed on the ground. 2 Share this post Link to post Share on other sites
WHX?? 49,916 #4 Posted June 16, 2017 Forget the worry Tg...just introduce yourself to Brian (Buckrancher) and make some friends...I'm pretty sure he will have a nice fire to enjoy! You may have to put up with @squonk tho! 3 Share this post Link to post Share on other sites
Tgtack 779 #5 Posted June 16, 2017 Thanks, fire ring suggestion? Share this post Link to post Share on other sites
benji756 341 #6 Posted June 16, 2017 depending on how big you want it you can cut the center out of a old steel rim. 2 Share this post Link to post Share on other sites
squonk 41,922 #7 Posted June 16, 2017 6 hours ago, WHX11 said: Forget the worry Tg...just introduce yourself to Brian (Buckrancher) and make some friends...I'm pretty sure he will have a nice fire to enjoy! You may have to put up with @squonk tho! I'll be chewin the fat under the lights in Chambersburg. Share this post Link to post Share on other sites
Zeek 2,286 #8 Posted June 17, 2017 I use a an old truck rim like this one. I have two. They sat outside for 25 years and never rust out, they are too thick. Plus you can stack them if you want. The only place I have seen fire rings used is in the wooded area where tents (and buckranchers rig) usually are. I have never seen one used where the campers park (where the power pedestals are), so make sure you pick the right location when you arrive if that is your plan. Share this post Link to post Share on other sites
