tallen4392
C--81
tallen4392
Can u guys tell me what hooks to the plow  and to the lift arm  I just picked up this machine the plow was not on it it has the rear axle mount but nothing on the arm that lifts the plow up and down what is the correct piece that should be there  thanks
953 nut
Take a look at this manual, it should answer everything.
nylyon
tallen4392
Where can I get the lift rod I think that is what is missing there is a chain hanging under the tractor
There is one on e slay for a raider 10 don't know if it is the same what's with the chain under there ????
nylyon
By lift rod you mean that vertical rusty piece of metal in picture 4?  You can try eBay, put in a wanted in the classifieds , check with some of our used parts vendors or check with Lowell, he may be able to do something https://wheelhorsepartsandmore.com/index.html
tallen4392
Do you know why the chain is there
SylvanLakeWH
I use the chain to lift / lower the front dozer blade on my C-105. (do not have a lift rod). Works great. Drawback is you can't apply down pressure, but I have never needed it and it performs very well on our Michigan snow (powder to slush to ice - all within the same storm usually!)...:)
tallen4392
thanks a lot
