mikekot3
What is the torque needed for pulley spindle bearing preload in a 42 inch sd mower deck?
mikekot3
I am replacing with new spindle assemblies of my model 78345 mower deck. I am unable to find in the manual section what the torque needed to preload the pulley to spindle
bearings under the protective covers on top of the mower deck.
I found the torque required for the blades to be 80-120 lb ft in one of the manuals here.
Please advise or tell me which manual it is found in.
Thank you,
Mike
Edited by mikekot3
gwest_ca
The 05-42MS04 deck uses the same bearings so suspect the spindle housings are identical but have never compared all the housing assembly parts. There is a handy chart on all the different spindle assemblies 1969-1989 so the last Z page gives you the torque specs. The Z bearings are metric OD and ID.
Click on the small grainy photo and it will enlarge so you can read it.
Noticed this service bulletin also comes up
Garry
mikekot3
Hello Gary,
Thank you for helping me find the information I needed. I now know to torque the pulley to spindle bearing nuts to 50-90 ft lbs.
Edited by mikekot3
typo
  • Similar Content
    • rustyedge1
      By rustyedge1
      Old gear drive covers in used condition.
      PM for details
      PayPal preferred, other payments accepted.
    • davem1111
      By davem1111
      I thought I'd circle back and see if I can fix a 42" deck (05-42MS05) that came off of one of my previous tractor purchases. I got the blades off and the bottoms of the spindles look good, and it needs some metal welded on where the wheel height adustment bracket bolts on. No big deal.
      The problem I'm having now on this deck is that I can't get this one spindle off. I haven't gotten the others off either, but they seem to be fine. This pulley is flopping around and obviously needs help. I've tried heating it with a torch after spraying it with penetrating spray numerous times, and it won't budge.  At this point, I'm thinking that I'll just need to grind it off, right through the spindle shaft, unless I can successfully cut through the thick ring without damaging the spindle shaft. If I have to grind through the pulley, it probably doesn't matter because I think it's shot already. Anyone have any other ideas?
      One question:  Is that thick ring supposed to be part of the pulley? This one is detached and the pulley spins freely (and sloppily).  Assuming I'll need to buy a new pulley, but was hoping not to have to buy another spindle shaft also. I did take the grease zirk off and have hammered on the top some, but only with a block of brass in between. It could already be damaged there.
      The picture doesn't help much, but here it is:
    • Joe Warren
      By Joe Warren
      one new old stock spindle housing
      part number 106063
      $79 includes shipping within US lower 48.
    • Rob R
      By Rob R
      Hi guys need you help have a 42" side Discharge Deck (Triple Blade) mower deck, mounted on a C-81, that is in bad need of an outside Spindle (Mandrel) the pulley on top is # 5877. The bottom bearing is toast. so I poise the following questions. Note pics attached.
      1. Does any on have one of these for less then a Kings ransome?
      2. Is it possible to disassemble and install an new bearing from like NAPA?
      3. All three spindles have NO Zerk grease fittings can I drill and add some...... if yes where on the housing is the best place to do this.
      Thanks feel free to add any other options......
    • jerryme
      By jerryme
      Hi everyone I'm looking for the center/drive spindle assembly with double pulley for my 1985 36" rear discharge wh mower deck. The only #'s  I have are off the mower deck. 85-6MR01-08150   8038. Any help is greatly appreciated. Thanks
