B-100
36" rear discharge level adjusting rod
B-100
I have a 75 (ish?) B-100 with a 36" rear discharge deck. I was mowing today and found that I couldn't raise the deck up and lock it, and found that the level adjusting rod assembly had came off, and after 2 hours of looking, couldn't find it. Does anyone know if this is still available anywhere?  I've attached a photo from the manual, I'm missing the rod, trunnion, and nut.
daveoman1966
That rod and trunion is about 5 in long...right?  If so, I ahve one and can put it in your USA mailbox for.  $15....
my email address is:
daveoman@windstream.net
contact me there for further details.
B-100
I'm not real sure on the length, I only have the picture to go by now. Maybe someone that has one of these decks could verify the length?
Tankman
1/2-13 all thread and two trunnions would work if you can't find the rod you need.
I have a large BIG horseshoe magnet, on a rope. I sometimes send the grandsons out to collect hardware, nails, bolts, out to collect metal. :icecream:
slammer302
I've made my own with a long bolt and cut off wheel and bending the bolt in a vise
