Forge Farmer
wheel horse 753 transmission gear
Forge Farmer
Hello new member here I have a 753 serial no 62-22031 I need transmission pn3525. The small gear on the end of the cluster gear is ground down so I have no first gear. Was caused by previous owner shifting with a screw driver causing it to atempt  getting in two gears at once.
stevasaurus
For those reading this...he needs the cluster gear for a #5025 transmission.  I would send a PM to @A-Z Tractor here on Red Square.  You can also try to get a hold of @racinfool40 (Mike) on facebook / wheel horse junkies.  One of these guys will have your part.  :)
Forge Farmer
Thanks for the info Steve.
oldredrider
Another option: "new" transmission.  I will be bringing a 5025 to the big show. Excellent condition, includes brake band and rod and new boot. Just sayin'...
Forge Farmer
I would consider that as I may be at the show. The transmission I have is in great shape otherwise. What would be your price. Would that transmission be a pre '65 that has shifting issues.
Edited by Forge Farmer
oldredrider
Don't know the year but shifts great...solid gear shift action. Asking $100.
Forge Farmer
I may consider it. Thanks.
Racinbob
I might be able to help you out here. I need to check what I have. Stay tuned. :)
Racinbob
Well, change to another channel. I thought for sure I had an extra cluster gear but no luck. Check with the other guys Steve mentioned. A good one shouldn't be hard to find. :)
